How to adjust the low beams?
Old Jul 27, 2001 | 09:26 AM
itrsport.com's Avatar
Default How to adjust the low beams?
Does anyone know which direction (clockwise or counter clockwise) while using a screwdriver to adjust the low beam lights. I don’t think the owners manual explains this topic very well. I attempted to experiment with one direction and then the other but even after many rotations I was unable to see a change in the light angle.
Another interesting thing I notice was that the low beam lights almost completely overlap. This means that even though I cover up one light completely, the full beam pattern on the road stays almost the same (except a bit dimmer). Anyone know what I'm talking about? This is another characteristic that makes the lights difficult to adjust.
I discovered this one night when I was trying to raise my left low beam. I realize that the left low beam should be slightly lower.
Old Jul 27, 2001 | 09:39 AM
ITR583's Avatar
New User
Default Re: How to adjust the low beams? (Black ITR 547)
Oh, man, I know what your sayin' brotha.
The two things I have a problem with is the site line behind the car through the huge wing and the SHITTY low beam coverage of the lights. I was going to get fogs, but first tried the same thing you're talking about.
There is a level on each of the lights(there may even be a directional arrow to show which way to turn). Anyway, turn one way and watch the bubble. I turned mine up and out and got little/ no response as far as being able to see at night. I just leave my brights on until I really HAVE to dim down.
Like I said, I think fogs are the best option.
Now....If I could just get a clear wing to see through....
Old Jul 27, 2001 | 09:45 AM
Cosworth's Avatar
Josh- Are HIDs still not giving you enough light coverage??? Your input would help all those waiting ot purchase the HID kit.
Old Jul 27, 2001 | 10:05 AM
Default Re: How to adjust the low beams? (Cosworth)
Like I said before, the HID's are very impressive. I'm just interested in aiming the low beams higher.
Old Jul 27, 2001 | 10:13 AM
GRM Scott's Avatar
25 Year Member
there is a bubble-level and a linemark indicator for each light assembly, use this to determine if you're raising or lowering, and moving left or right.
sanggggiee
May 23, 2012 06:09 PM
bmaya
Honda Civic (2006 - 2015)
18
Mar 6, 2009 05:16 AM
Insperation
Mar 23, 2005 12:34 PM
xmattoxx
Oct 27, 2002 02:14 PM
97GSR
Sep 26, 2001 01:38 AM
