1st time at the track with the B17
r/t 0.433
60 2.337
330 6.417
1/8 9.787
MPH 74.02
1000 12.666
1/4 15.111
MPH 92.14
The only mods I currently have are an air intake, chiped 28, and safc. It was nearly 100 degrees out when I ran at Lebanon Valley here in NY. The car fells like it can be slightly quicker. Any suggestions?
60 2.337
330 6.417
1/8 9.787
MPH 74.02
1000 12.666
1/4 15.111
MPH 92.14
You need to bump up the compression. The b17 has less than 10.1 compression. You can gain real good # with ctr pistons & cams.
I'm getting a set of CTR cams probably this month. I was going to do the CTR pistons over the winter. How much of a difference should this make in the numbers?
my stock b16 ran a 14.9 i just have a cheap filter and exhaust and my friends with same mods ran a 14.6 my 60 foots are real bad bt my mph is 96...i dunno that seems kinda weak for a b17... i may be wrong who knows...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hondasaurs »</TD></TR><TR><TD CLASS="quote">
What year and trim car is this? Also what are you launching at? The 60ft time is could be better.
theslugbug
Aug 11, 2004 12:37 AM
