Upgrade Bushings? Tools needed?
Well if I am getting that high mileage R then I probly need to replace all the rubber bushings. My question is that how powerful a press do I need to pop those suckas out? 12 ton? 20 ton? or can a 6 ton one do?
Also which bushing kit should I get. Stock from acura, Energy supsensions, or some Bling Bling JDM kits.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PyR01-0347 »</TD></TR><TR><TD CLASS="quote">Well if I am getting that high mileage R then I probly need to replace all the rubber bushings. My question is that how powerful a press do I need to pop those suckas out? 12 ton? 20 ton? or can a 6 ton one do?
Also which bushing kit should I get. Stock from acura, Energy supsensions, or some Bling Bling JDM kits.</TD></TR></TABLE>
none.. a blow torch.
Well the blow torch is a option. But I still want to get a Shop press never the less. So what I need to know is how powerful a press I need to get the job done fast and easy.
Also I want to know which bushing kit should I go with? ES?Mugen?Spoon?OEM?
i heard that urethane inserts start to sqweak after time...
Mugen's are the best ones out... they aren't urethane... i think those are actually a stiffer type of rubber... but i'm not totally sure.
for a street car, most people rave about the mugen bits. they are a harder rubber than oem, but won't squeak like urethane. you could also just replace the old with new oem bushings.
Mugen's prices are outrageous. I think it's actually cheaper to buy replacement control arms in many cases than to buy the damn bushings from King/Mugen. The only Mugen bushing I'd consider is the trailing arm one.
I know 2 Grand-Am ITR's with the full Mugen bushing kit, and they said they couldn't tell a difference b/w that and stock :-/
Warren
Warren
wicked2night
Dec 31, 2006 07:34 AM
