b20Zvtec question..
Old Jul 1, 2003 | 12:14 AM
TriK's Avatar
Default b20Zvtec question..
block: b20Z
head: pr3 b18c5
piston : b20z valve relief enlarge to 33mm
can i use 1 layer head gasket?
thanks!
Old Jul 1, 2003 | 01:10 AM
xJ.SLOTHx's Avatar
Default Re: b20Zvtec question.. (TriK)
i wouldnt see any problems with using a "thinner" head gasket with that setup being that the compression characteristics of those pistons are about as aggressive as a sun flower. If you plan on using a Honda head gasket, I'd opt to just make it into a 2 layer and mill the head some.
Old Jul 1, 2003 | 02:37 AM
tinkerbell's Avatar
Default Re: b20Zvtec question.. (ian)
WTF?
aggressive pistons???
nah man, if you dont get it - the pistons are not designed for VTEC valves or VTEC type lift...
TriK - the only way to know is to clay your engine's valve clearances to know for sure...
Old Jul 1, 2003 | 09:37 AM
TriK's Avatar
Default Re: b20Zvtec question.. (tinkerbell)
arg i hate clay it take forrrrrrrrr ever
EG6 Love
Feb 16, 2010 06:25 PM
gundal
Aug 20, 2008 10:44 AM
dsnyder305
Sep 14, 2007 05:50 PM
TRuST
Aug 29, 2002 06:32 PM
