making the shift light work minus the tach
Old Jun 30, 2003 | 09:42 PM
94dc2gsr's Avatar
Default making the shift light work minus the tach
i got an autogauge tach w/ shift light and i dont want the tach, is there ne way to wire just shift light work without using the tach?
Old Jun 30, 2003 | 10:09 PM
Blaze45's Avatar
Brrraaaap!
Default Re: making the shift light work minus the tach (bobbo)
Bump cause I;d like to know as well, BTW, would it still be more accurate then the stock tach> the EDs tachs are off like 400-600 RPM depending on the car @ higher RPMS....
Blaze
Old Jun 30, 2003 | 10:35 PM
SHystrdyGSRtdy's Avatar
Default Re: making the shift light work minus the tach (Blaze45)
i had my shift light module + shift light wired to my ecu when i had my prelude.. prelude tachs are way off at redline so when it's wired to the ecu it was waaaay more accurate... about how to hook it up without the tach...dunno....
Old Jul 1, 2003 | 09:09 AM
luckypon7's Avatar
Default Re: making the shift light work minus the tach (iLUVmySH)
check out auto meter web site i think they might have something. it was like $100.
Old Jul 1, 2003 | 09:35 AM
Blaze45's Avatar
Brrraaaap!
Default Re: making the shift light work minus the tach (luckypon7)
Thats not what the question is,
Were wondering how to hook the shiftlight up w/ out a tach.
Blaze
Old Jul 1, 2003 | 10:13 AM
APEX CRX's Avatar
I have a MSD ignition and it has a port to plug up my autometer shift lite. if you don't have a ignition box then you can use a rpm activated switch like the ones people use to activate VTEC
Old Jul 1, 2003 | 10:24 AM
luckypon7's Avatar
i'ts not a tech it's module you wire to the ecu and you can set shift point.
.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blaze45 &raquo;</TD></TR><TR><TD CLASS="quote">check out auto meter web site i think they might have something. it was like $100.
Blaze</TD></TR></TABLE>
i don't think msd ignition box has a plug for shift light, it might look like it but it;s not. i called msd that plug that looks like it will fit is a megnetic pickup line. i have a shift light also trying to use w/o tech.
b20vteg757
Engine Management and Tuning
10
Nov 18, 2013 09:43 AM
civic-one
Feb 28, 2013 07:31 PM
cleanazcoupe
Mar 27, 2009 05:34 PM
crxzcracer
Jul 4, 2004 10:08 PM
Smokinsax
Jun 12, 2002 11:52 AM
