Doing my suspension, need some advice!
Old Jun 30, 2003 | 09:22 PM
B18CYAAA's Avatar
Default Doing my suspension, need some advice!
I am about to upgrade the suspension on my 94 GSR and I would like to get a quality suspension with a nice ride for daily driving but also one the can perform if I decide to autocross my car. I was planning on doing Koni Yellows with ground controls. However I am considering koni reds. What is the major difference? Also, I was considering doing H&R sport springs on the koni yellows. I don't want to slam it, just lower it and improve my handling. Which would be the best way to go? Also, will I need a camber kit? Thanx.
Old Jun 30, 2003 | 09:27 PM
zad5's Avatar
the difference is that they are externally adjustable. softness and hardness. The yellows have lifetime warranty and can also be serviced (to have a larger spring rate or be double adjusted or whatever). If you are going to autocross i think you should go get some custom rate ground controls and the koni yellows.
koczeka
Jan 29, 2007 12:41 AM
travisallenn
Suspension & Brakes
Nov 30, 2006 04:55 PM
turbotime
14
May 15, 2005 08:49 AM
SD99GSR
Dec 4, 2002 01:26 PM
Philbert
Aug 30, 2001 09:46 PM
