2 stripped headbolts.. if i take it out later will the head/block surface be warped?
Old Jun 30, 2003 | 09:14 PM
accordfreak's Avatar
Default 2 stripped headbolts.. if i take it out later will the head/block surface be warped?
i have two stripped headbolts while all the other headbolts are loose... if i wait until later to take them out will the surface of the block/head warp?
Old Jul 1, 2003 | 08:52 AM
PSU-TEG's Avatar
Default Re: 2 stripped headbolts.. if i take it out later will the head/block surface be warped? (accordfrea
It is DEFINITELY a chance I would not take.
My guess would be yes. That is why the Helms Manual tells you to losen the bolts each 1/3 of a turn at a time in the proper sequence.
If the head and block are completely cooled down, that would help keep it from warping.
But I think doing that would give the head better odds to warp than not to warp.
Don't chance it! You'll probably lose.
weekendboost
Apr 18, 2014 04:45 AM
CHEESEYeg6
May 29, 2012 08:26 PM
88 EF Hatch
11
Jul 16, 2009 10:14 AM
