Big favor needed from someone with a 98+ integra only
Old Jun 30, 2003 | 05:14 PM
shadowdawn's Avatar
Default Big favor needed from someone with a 98+ integra only
I need some voltmeter readings from your relay connectors.
If you have a helms turn to page 22-8 and perform the test in the middle of the page that states.
Measure the voltage from No 1 (+) connector and body ground, you should read battery voltage.
This is for the radiator fan relay connector (not the relay itself.)
For those of you w/o a helms but still want to help pop your hood, go into the fuse/relay box and take out the Radiator cooling fan relay. female connectors where the relay plugs up will look like this:
Below I have the #1 connector labled. (NOTE: that period in the middle is just there so I can space things out, it is not appart of the connector at all)
. | |<----- #1 connector
All you have to do is connect the black or red from the voltmeter to this connector and a ground (chasis or battery). With the car off, on, and on and started perform this test and let me know if you get ANY voltage whatsoever from doing this. Because in my case I am not, the same is with my condensor fan, and ac clutch connectors, 0 voltage.
Old Jul 1, 2003 | 12:17 PM
shadowdawn's Avatar
Default Re: Big favor needed from someone with a 98+ integra only (shadowdawn)
Up please
hmtcrxsir
16
Apr 9, 2017 11:13 PM
dc97
Oct 18, 2012 08:38 AM
iphatcrxi
Jun 14, 2006 12:36 AM
gutted-dx
May 30, 2005 11:08 AM
M-EJ1
Feb 23, 2005 12:32 PM
