My speedometer jumps all over the place, even goes backward.....HELP!!!
Old Jun 30, 2003 | 11:47 AM
~~~InNeEdFoRsPeEd~~~'s Avatar
* B A N N E D *
Default My speedometer jumps all over the place, even goes backward.....HELP!!!
like the topic says......TIA
Old Jun 30, 2003 | 11:59 PM
* B A N N E D *
Default Re: My speedometer jumps all over the place, even goes backward.....HELP!!! (~~~InNeEdFoRsPeEd~~~)
need help badly can't afford to get speeding ticket
Old Jul 1, 2003 | 05:32 AM
liquid51's Avatar
What year car do you have? My 89 prelude uses a speedo cable that runs through the fire wall and into the IP. The bushings (or something) wore down or came loose in the upper part of the cable, making it very sloppy in there. The result was exactly what you described. It would happen at night sometimes when I was a little tired, and started making me think I was having flashbacks
Old Jul 1, 2003 | 06:07 AM
* B A N N E D *
Default Re: My speedometer jumps all over the place, even goes backward.....HELP!!! (liquid51)
the car is a hatchback with jdm h22. doesn't seem like its speedeo is cable electronic speedeo?
Old Jul 1, 2003 | 08:48 AM
igotyofire's Avatar
sounds like distrubutor problem according to what my two other friends decribed happed to theres, same thing. did u just recently change the distrubutor? or do this swap? if so possibly whoever u got the distrubutor from sold u or gave u a fawked up one
Old Jul 1, 2003 | 11:46 AM
* B A N N E D *
Default Re: My speedometer jumps all over the place, even goes backward.....HELP!!! (igotyofire)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igotyofire &raquo;</TD></TR><TR><TD CLASS="quote">sounds like distrubutor problem according to what my two other friends decribed happed to theres, same thing. did u just recently change the distrubutor? or do this swap? if so possibly whoever u got the distrubutor from sold u or gave u a fawked up one</TD></TR></TABLE>
distrubutor and plugs all new (ngk)....the thing that i don't get is all the rest of the tech (rpm,gas,temp and odometer) are all in working order can it still be the VSS or just bad speedo needle?
Old Jul 1, 2003 | 11:53 AM
YumVTEC's Avatar
speed sensor fuse is blown probably. it's in the fuse box in the car, same fuse as the alternator.
mahatma
Aug 12, 2006 08:20 AM
Jonknee
Jun 1, 2006 08:38 PM
DOHCRX
Mar 28, 2003 08:22 PM
