Question: How to remove rear seats
Old Jun 30, 2003 | 11:37 AM
SpeedFiend's Avatar
Default Question: How to remove rear seats
I've been trying to remove a four-point harness that a shop installed for me. I need to remove the rear seat to get to the mounting points. What's the best way to do it? Thanks.
Old Jun 30, 2003 | 11:55 AM
RTW DC2R's Avatar
Default Re: Question: How to remove rear seats (Michael)
take off the back portions first. there is a small black clip on the outside of each seatback. lay the seat down, and look for it between the interior plastic and the seat. pop those off, and you can slide the seat toward the wall and pop it out. the seat cushion has a 10mm bolt that holds it down, you cant miss it. there is a slight "lip" on the front of the cushion to help hold it down, so you may have to push the seat back before you can lift it up. be careful when you push the seat buckles through the cushion so that you dont rip anything. its cake.
EDIT: I cant spell cushion, 3 times.
Old Jun 30, 2003 | 11:59 AM
sa04's Avatar
http://www.sa04.com/typer/rearseat.jpg
Old Jun 30, 2003 | 12:18 PM
SpeedFiend's Avatar
Default Re: Question: How to remove rear seats (sa04)
Great. Thanks for the input and the diagram. Now if can just get that diagram to print on one page...
Old Jun 30, 2003 | 12:20 PM
Chris N's Avatar
It is fairly easy once you get started.
The only part that is a bish is getting the clips on the lower part of the rear seats to come loose... and in comparison to other PITA bolts and stuff like that on the car, it is VERY easy.
EZ$$EF
Sep 17, 2008 12:17 PM
99_turboteg
Jan 9, 2008 04:40 PM
89sicivic
Mar 9, 2007 04:57 PM
magic hat #9
Dec 24, 2002 06:40 PM
Attoir
May 22, 2002 11:44 AM
