have done searches and have hondata questions
I have a 99Si with a JRSC I want to go hondata. I also have a p28 ECU. other than just getting the s200 with boost option what else do I need to do other than get the ECU socketed? basically I want a plug and play setup with a pretuned JR map. thank you. Also who is the cheapest to buy this system from??
What you need:
S200b
P28 (is fine must be socketed for hondata) Hondata charges $65
OBDII to OBDI Harness or you can get an OBDI converted ecu from hondata
PM Kyle (2K_teg) he has the best prices I have seen.
PS. There is no such thing as plug and play standalone. The base maps are only to help you granny yourself to a dyno. It MUST be tuned for your specific engine.
S200b
I know there is no such thing as a plug and play but they are selling them with preprogrammed base maps. And I guess I will need the adapter harness. I tried to call kyle at KS but they are gone till after the 4th of july so I am tring to something in the meantime. anybody else???? thank you
crazyitr
Sep 30, 2006 12:39 PM
