Field SFC Tach Question
Old Jun 30, 2003 | 10:40 AM
Padawan's Avatar
Darth ModerVader
Default Field SFC Tach Question
Well, we recently installed a Field SFC in my brother's car (thanks again to those that helped with the ECU pin-outs). Every wire was soldered (and shrink-tubed except for the taps) and there are no problems with the operation of the unit and no CEL.
The one thing we have noticed, however, is that the tach feature seems to be consistently "off" by approximately 200 RPM when compared with the stock tach. I am aware of the stock tach's accuracy problem, especially at high RPM, but the Field unit indicates ~200 RPM lower across the rev range, all the way to redline. I had always assumed that the stock tach was reasonably accurate at low RPM's, but that doesn't appear to be the case when comparing it with the Field display.
Has anyone else experienced a pessimistic tach on the SFC? The RPM signal we are using is the ICM wire, which I am almost completely certain is the correct feed.
Old Jun 30, 2003 | 02:35 PM
SlapSmak's Avatar
Default Re: Field SFC Tach Question (Padawan)
same controller here, same readings. I am certain the Fields is correct, unless my rev limiter is off by 4oo RPM. The stock tach suks ***
Old Jun 30, 2003 | 04:25 PM
Todd00's Avatar
I said I don't want a title!
Fields is more accurate than the stock tach. Stock tach reads 9K before the limiter hits on my car, whereas field is right on at 8500.
G2integra217
Jun 12, 2005 11:13 AM
WhiteGSR95
Mar 29, 2005 08:11 AM
slow94civ
Dec 24, 2004 09:09 AM
BiG Chris
Oct 11, 2004 05:58 AM
1fastGSR
Nov 25, 2001 06:14 PM
