Stock fuel pump w/JRSC
I wouldn't recomend it. It's always better to be safe then sorry. At least upgrade to a intank 255lph high volume fuel pump like the holley/walbro unit. It's only about $130 and it will support your set-up a lot better then the stock
Yes, the stock pump is fine. 42psi static fuel pressure with fpr @ 1:1 rise rate and 440cc injector @ 8psi boost = only 50psi WOT fuel pressure and approx. 55% injector duty cycle.
escape2me
Sep 30, 2005 07:29 AM
