skunk 2 manifold on gsr
i have a 95 gsr and i put a skunk 2 intake manifold on it and i was wondering if there is any good vafc fuel curves i should try. the car also has basic bolt ons intake header, exhaust....thanks
you should get your vafc tuned at a shop... or go ghetto style and go by the seat of your pants dyno... but id just keep in mind the S2 IM intakes more air so i'd rekon that you would have to slightly adjust the fuel curve and add a little more fuel.
Get it tuned. It's the only way you will know for sure. I'm running CTR cams with VTEC x-over at 4800 and running about +13% between 4500 and 6000 and about +5% after that. A/F ratio os between 13.5 and 14.0. hth The hp curve is pretty flat up to about 8k. 171 whp and 122 tq
Fez
May 22, 2002 08:04 AM
