At the track with slicks the first time
i went to the track with slicks but i wasnt running the right psi of air. with that kind of traps what should i go with a good 60'?
60' 2.16
330' 5.86
1/8 8.78
mph 84.44
1000' 11.29
1/4 13.39
MPH 107.13
60' 2.16
330' 5.86
1/8 8.78
mph 84.44
1000' 11.29
1/4 13.39
MPH 107.13
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by singleslamrex »</TD></TR><TR><TD CLASS="quote">drop the psi,</TD></TR></TABLE>
i was thinking about going down 1 psi a time to try it out
I had the same 60ft problem. I don't know if my slicks are too big, wrong psi, wrong rpm, or maybe a combination of all. I just got my quaife in so hopefully that helps out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whatVTEC »</TD></TR><TR><TD CLASS="quote">Whats your setup? All stock or is your block built? How big of a shot?</TD></TR></TABLE>
i have a completly stock motor with a DC 4-2-1 header gutted cat Apexi muffler short ram intake coilovers and struts 255 lph intank pump
full intior with a wet NX kit dual stage 75 primary and a 35 on top of that with colder plugs and timming pulled i dont rember off hand how much but about 4 deg or so pulled
next i am going forged pistons and rods with 11:1 compresion and ctr cams slight port polish and more spray
my kit is a dual singgle nozzal kit no DP on a b18c1
Modified by bottlefedb18c1 at 11:07 PM 7/1/2003
I'm betting the slicks were at 14-15 psi after burnout, if not higher!!!!!
20x8x14, 12 psi warmed, 7800 rpm launch, spraying righ from the launch.
1.816 on SOHC.
With 22x8x13's I'd better cut a 1.77!
1.816 on SOHC.
That is nearly identical to my slip hehehe
If I ran slicks, I'd be at 9 or 10 psi...
With good 60"s you'll probably drop back to 106mph which "should" get you 12.6ish
