Tips and tricks: Cleaning the EGR ports???
Old Jun 30, 2003 | 09:13 AM
SOHCMAN's Avatar
Default Tips and tricks: Cleaning the EGR ports???
Just looking for some experiance with this... I can find them and clean them, but I dont want to mess anything up (say by using a solvent I shouldent) and what are you really looking for that you want to clean??
thanks.
sohc
Old Jun 30, 2003 | 09:54 AM
RotaryBzzzz's Avatar
Default Re: Tips and tricks: Cleaning the EGR ports??? (SOHCMAN)
You want to clean out the mess of carbon buildup. I used a dental pick and spray-Carb Cleaner. I'd wear eye protection and a mask when using the spray.
The carbon itself has the consistency of flaky-goo. You poke-it and it falls down into the chamber. Ideally, if you had a shop vac with a needle nose type of attachment (improvise here w/ a straw or small tube?), that would be ideal to suck out the fallen carbon bits before really hitting it with the Carb Cleaner.
Old Jun 30, 2003 | 10:52 AM
YeuEmMaiMai's Avatar
for 94-97 cars you have to remove the fuel rail. it is best to get all the loose crap out and use a wire pipe cleaner to cleam out each opening.....I would avoid using a shop vac once you have sprayed carb cleaner in there......
Old Jun 30, 2003 | 10:55 AM
SOHCMAN's Avatar
Default Re: (YeuEmMaiMai)
interesting, thanks for the idea of using the shop vac!
sohc
Old Jul 14, 2003 | 01:17 PM
Butler230's Avatar
Default Re: (SOHCMAN)
Just wondering, what would be the reasoning behing cleaning the egr ports?
Old Jul 14, 2003 | 02:09 PM
Chiovnidca's Avatar
Default Re: (Butler230)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Butler230 &raquo;</TD></TR><TR><TD CLASS="quote">Just wondering, what would be the reasoning behing cleaning the egr ports?</TD></TR></TABLE>
Clogged EGR ports can cause a hesitation at part throttle while driving or they can cause emmision test failures.
bromozee
Sep 6, 2013 07:30 AM
jDm_eDm
Aug 19, 2006 02:37 PM
unrefined7
Jan 5, 2006 04:11 PM
PreStaged12s
22
Jun 17, 2005 07:51 PM
JDMEJ94EX
Feb 25, 2004 10:33 AM
