Shocks and struts for 1986 civic hatchback (for SOLO II autocross)
I'm new to autocross and just picked up a honda civic Si hatchback (1986). It'll be a great car for solo II (G stock) as soon as it gets some suspension work. It needs shocks, struts, and springs. Can someone recommend something and where I can get it? Thanks.
I recommend a rule book as the modifications you listed are going to take you out of stock unless you use standard OEM parts.
https://honda-tech.com/zerothread?id=353425
From: boldly scornful of higher mental function, US
Koni makes a great shock/strut for this car. Springs are not changeable under stock rules.
A complete bushing refresh and new ball joints will really help out as well. The ball joints are legal for stock. Make sure you stick with OEM bushing material if you plan on doing that and staying in GS.
I bet they do, but I don't think I can afford them. I was thinking KYB sports. I only paid 350 for the car, so I'm trying to do this grassroots cheap.
there's no such thing as 'kyb sports'
the only thing offered for a '86 hatchcrap is KYB GR-2's which are just factory replacements.
Konis will be $500 or so from tire rack ( http://www.tirerack.com/suspen...2&y=2 ), probably a few $$ cheaper from http://www.shox.com
Thanks madhatter.
if I decide to get into STS, what bushing material should I go with, or does it have to be OEM for that, too?
Tokico makes a set of externally adjustables for around 400... hmm... I guess someone does make something for the ole hatchcrap. Thanks for all the help guys.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oldskoolcivic »</TD></TR><TR><TD CLASS="quote">Thanks madhatter.
You can have poly bushings in STS.
jaxle
Aug 23, 2003 06:33 PM
honda_joe
Feb 28, 2003 07:50 PM
