weird ass ticking sound when i start my car
Old Jun 29, 2003 | 10:01 PM
junya16's Avatar
Default weird *** ticking sound when i start my car
it sounds like a rough metal to metal ticking sound...it always starts and the car seems to be running fine but it is just a very out of the ordinary sound and i have no idea what it is....any suggestions??????
Old Jun 29, 2003 | 10:09 PM
jonoknut's Avatar
Default Re: weird *** ticking sound when i start my car (junya16)
well open your hood and see where its coming from, it could just be a worn belt. im not sure what the valve ticking sounds like when u f*ck em over. . but i think that would effect your performance so. . .
Old Jun 29, 2003 | 10:21 PM
P1mpSlap's Avatar
vavle tick sounds just like what it is. Just a light tick noise during idle. It's not really that loud, but it's noticable.
Old Jun 29, 2003 | 10:56 PM
Loveless's Avatar
Default Re: (P1mpSlap)
yep, and when you apply alittle gas the ticking goes by faster
you might wnat to do a valve adjustment
Old Jun 29, 2003 | 11:12 PM
K.F14's Avatar
Default Re: (Loveless)
Its your valvetrain..you're going to need an adjustment done.I had the same problem.
Old Jun 30, 2003 | 01:53 AM
junya16's Avatar
Default Re: (Tenzo R)
it only does it when its turning over and it whenever it comes off a rev it almost bounces off 0rpms and it even died once tonight while driving
Old Jun 30, 2003 | 08:13 AM
Witty's Avatar
Default Re: (junya16)
Could be a valve problem. Does the ticking stop when your motor warms up?
Old Jun 30, 2003 | 08:41 AM
94dc2gsr's Avatar
has the car overheated lately? after i overheated my old prelude the valves would tick like crazy
Modified by bobbo at 5:51 PM 6/30/2003
Old Jun 30, 2003 | 10:27 AM
junya16's Avatar
Default Re: (bobbo)
no i don't hear any ticking after it starts runnin... and no it hasn't overheated recently...
Old Jun 30, 2003 | 10:39 AM
ajchen's Avatar
with a motor like yours, i'm surprised you havent even thought of doing a valve adjustment. jun3's with bumped compression are no joke. you need to monitor that crap constantly and do a valve adjustment at LEAST every 5k miles to be safe. do that and see if the ticking goes away.
Old Jun 30, 2003 | 10:49 AM
SmurfDA's Avatar
From: I live in a town with Boston traffic, mass, united states
Default Re: (ajchen)
i had a similar metal on metal noise in my old civic ex, sohc vtec baby, lol, but it ended up i spun a berring on the crank and the piston was almost contacting the head, the symptoms were a flickering oil light, drop in rpms, it would stall and made an ocassional pinging noise, not to scare ya, just my .02.
Old Jun 30, 2003 | 05:04 PM
spd18's Avatar
my car also ticks. i can hear it at idle, and when my car is moving you can still hear it, and it speeds up. i always thought getting a valve adjustment would fix this. i dont know if i am losing power from this, or if it just makes a ticking noise. how does one do a valve adjustment? can someone do it themself or is it necessary to have a shop do it? sorry if that doenst make sense..
Old Jun 30, 2003 | 08:18 PM
VTECorona's Avatar
Default Re: weird *** ticking sound when i start my car (spd18)
Injectors tick
Old Jul 4, 2003 | 01:22 AM
junya16's Avatar
Default Re: weird *** ticking sound when i start my car (VTECorona)
well i found out the loopy idle was from the timing belt and i got that tightened up and its good to go now....and i got a different starter and it took care of the grinding sound and now there is just an 1 raspy metal to metal sound(only when it is turning over)car runs fine once its actually started...and i checked out the valves and they're ok...i also came out to my car today and it was completely dead(battery had zero fluids) fixed the fluids and it barely got started up...came out later that same day..car was completely dead again(fluids full)..had to get a jump and car barely started....went and got battery checked out and it is ok....so now i am officially lost as to what it is???????HELP ME OUT GUYS
Old Jul 4, 2003 | 03:03 AM
MikeSarr_GSR's Avatar
inspect the bearings
Old Jul 4, 2003 | 05:00 AM
Jay J's Avatar
Prince of Zamunda
Default Re: weird *** ticking sound when i start my car (MikeSarr_GSR)
check the oil
Old Jul 4, 2003 | 06:54 AM
..::91TEG-G2::..'s Avatar
hey, my car does that too, that damn ticking noise... umm how would you get a valve adjustment..? would you have to have someone do it for you or can you do it?
Old Jul 4, 2003 | 01:50 PM
junya16's Avatar
Default Re: weird *** ticking sound when i start my car (neuspeed)
oil pressure is good when it gets running and i haven't inspected the bearings yet but wouldn't the car run like **** once it got going if it was the bearings?
Old Jul 4, 2003 | 03:10 PM
VTECorona's Avatar
Default Re: weird *** ticking sound when i start my car (..::91TEG-G2::..)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ..::91TEG-G2::.. &raquo;</TD></TR><TR><TD CLASS="quote">hey, my car does that too, that damn ticking noise... umm how would you get a valve adjustment..? would you have to have someone do it for you or can you do it?</TD></TR></TABLE>
You can do them yourself just make sure you have a clue what you're doing and have a helms handy (not haynes or chiltons). If you're not a do-it-yourselfer then bring it to the dealership. I think they charge like 80-90 for it.
Old Jul 4, 2003 | 05:29 PM
4crx4me's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by junya16 &raquo;</TD></TR><TR><TD CLASS="quote">it sounds like a rough metal to metal ticking sound...it always starts and the car seems to be running fine but it is just a very out of the ordinary sound and i have no idea what it is....any suggestions??????</TD></TR></TABLE>
My CRX w/D15 made a similar sound at cranking after overheating.
It went on for a couple of months like that, I didn't worry till one day the water pump blew apart. Now whenever I start it, it sprays coolant all over the bottom of the engine bay. haha
Old Jul 5, 2003 | 12:01 AM
Default Re: weird *** ticking sound when i start my car (4crx4me)
a car can run perfectly fine with a rod knock. rock knock can be minor and still hear it and the car drive like normal. it will eventually get worse over time and eventually s*it metal in your engine if thats the problem...
Old Jul 5, 2003 | 02:05 AM
junya16's Avatar
well i finally found one of the problems and it was the metal piece that connects the battery fuse to the actually battery cable was broken so there was a weak connection going on there so i'm gonna go junkyard hunting in the morning and hopefully take care of that....i'll let you know how it goes
Old Jul 11, 2003 | 03:17 PM
junya16's Avatar
well the problem was i had a 92 starter on a 98 block and the starter stripped my flywheel....but luckily for me the people at comptech hooked me up w/ a free replacement and got another starter for 100 bucks...runs like a champ now
joshmak
Jun 13, 2010 10:07 AM
EG-SIXV-TEC
13
Jun 15, 2009 12:49 PM
Ideal
Sep 14, 2005 02:43 PM
adam_reiland
Apr 26, 2005 07:56 PM
Ibuprofen
Oct 5, 2002 01:07 PM
