accord 4ws
Old Jun 29, 2003 | 08:08 PM
ChaosUnbound's Avatar
Default accord 4ws
dose anyone know if it would be posable to take the 4ws off a lude and put it on a 4th gen accord
Old Jun 29, 2003 | 10:07 PM
briq4's Avatar
Default Re: accord 4ws (ChaosUnbound)
I think that an early 90's Non US market Accord Model could be had with 4ws on them, so I'd assume anything is possible. Not sure if the two are interchangeable. Actually some guy on here had a picture of his Accord posted up with the 4ws and what those 4 knockouts are for in the ceter console (near the emergency Brake) Wish they would have put heated seats in the Accords sold in the USA back in the 90's.
Modified by briq4 at 2:53 AM 6/30/2003
Old Jun 29, 2003 | 11:06 PM
briq4's Avatar
Default Re: accord 4ws (briq4)
finally found the topic.
https://honda-tech.com/zerothread?id=412935
Old Jun 30, 2003 | 12:38 AM
TypeSH's Avatar
the question is, how exactly does the 4WS system work? and what additional parts are used for such a system?
then you would try and see hwo the system is rigged on the overseas models and/or the 4th gen prelude w/ 4WS
Old Jun 30, 2003 | 05:41 AM
Martaigne's Avatar
Default Re: accord 4ws (TypeSH)
I believe it's a steer-by-wire system... a signal goes to the rear rack and it does what it needs to do. When going under 25 the car will response by turning the rear wheels in the opposite direction of the front, so increase turn-in. When cruising at interstate speeds, the rear wheels turn in the same direction as the fronts, to make lane changes and avoidance maneuvers a lot smoother.
emraldgtr1
Aug 4, 2007 02:46 PM
nonvteclude
Sep 4, 2006 06:41 AM
kevinm1981
Jun 18, 2004 12:46 AM
