Ls Swap
Old Jun 29, 2003 | 05:19 PM
Gentryjracer's Avatar
Default Ls Swap
I bought a ls motor. How hard is it to do the swap? It's going into a 98 hatck. Is there any place or any on that has step by step instructions? Would like to do it myself. I'm not completly sure what all it takes.
Old Jun 29, 2003 | 05:20 PM
BYT's Avatar
BYT
Default Re: Ls Swap (Gentryjracer)
https://honda-tech.com/zerothread?id=131949
Old Jun 29, 2003 | 06:28 PM
94si94cx's Avatar
Default Re: Ls Swap (BYT)
It helps to know what year your motor/ecu is.
Old Jun 29, 2003 | 06:54 PM
Default Re: Ls Swap (94si94cx)
The motor says it was made in 91.
Old Jun 29, 2003 | 07:25 PM
94si94cx's Avatar
Oh ****. I'm sure there's a way to do it, but good luck with finding an answer. Mounts should be the same as any b-series in a 96+ civic, but the wiring is gonna be a bitch.
Old Jun 30, 2003 | 12:00 AM
beseman's Avatar
hahah good luck with the planning you have, everything should bolt up fine except for the wiring harness.......good luck if you dont know what you are doing
Old Jun 30, 2003 | 12:54 AM
krazyDOHC's Avatar
Default Re: Ls Swap (beseman)
you need a bseries tranny from 94+ hydro
AdamN
May 5, 2011 04:02 PM
jdmed3
Oct 28, 2008 09:52 AM
SOHC_4dr
Jun 19, 2008 11:36 AM
TenLarge
May 5, 2005 05:44 PM
Dropped90Integra
11
Nov 30, 2004 01:56 PM
