axle problems.....
Old Jun 29, 2003 | 05:03 PM
DXturbo's Avatar
Default axle problems.....
im having a slight problem putting my axle in. hope fully you guys can help.
i have a 93 dx and i just swapped in a d16z6 from a 95 si with abs. anyhow, the axle goes in the tranny but it wont go in the hub (passenger side). does this mean that my hub is messed up?
Old Jun 29, 2003 | 05:05 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: axle problems..... (DXturbo)
you're probably not going straight into the hub....pull the hub away and make sure you're going straight in.
I've never had any problems
Old Jun 29, 2003 | 05:11 PM
DXturbo's Avatar
Default Re: axle problems..... (Emerika)
ive tried that many times. ive done tons of motor swaps but this one is just being difficult. i tried to stick it in straight in but it still doesnt go in. how do you know when your hubs are messed up?
Old Jun 29, 2003 | 05:12 PM
miataguy's Avatar
I just replaced my axles this weekend and had the same problem. You have to wiggle the hub up and down while pushing the axle in. I also found that jacking up the lower control arm so that it allowed the axle to be straight helped a lot.
Old Jun 29, 2003 | 05:52 PM
DXturbo's Avatar
Default Re: axle problems..... (miataguy)
thanks for all the replies! i was examining it a bit more and noticed that the splines are messed up inside the hub. so i guess i need a new passenger side hub.
RanCRX
Dec 28, 2009 03:03 PM
t3601
Transmission & Drivetrain
Dec 3, 2009 01:53 PM
JDM_LS
Jun 28, 2008 09:34 PM
lowered94accord
Mar 16, 2007 10:43 PM
JDM96SpecCTR
13
Dec 6, 2004 01:34 PM
