help! engine wont start
Old Jun 29, 2003 | 03:35 PM
b16ej1lsd's Avatar
Default help! engine wont start
I was driving in a pretty bad storm when i hit a deep puddle. My engine died and i had to pull off to the side of the road. When i tried to start it the solenoid just makes a single click and then the lights on the dash dim, the fuel pump comes on and then silence. Ended up having to have it towed home..... Today I removed the air filter....which turned out to be pretty damn wet. then i pulled the plugs...they were wet and there was NO carbon on them which seemed odd since i haven't changed them since i bought the car 2 years ago. The ecu is throwing code 92 - Evaporative Emission Control System insufficient purge flow
what should i do next?
this is a 95 civic ex btw..
Old Jun 29, 2003 | 04:49 PM
b16ej1lsd's Avatar
bump
Old Jun 29, 2003 | 04:56 PM
TrickHonda98's Avatar
Default Re: (klear)
never heard of this, sounds odd. If you have upgrades to your car (alot) let a proffesional tuner/mechanic look at it. If has nothing (stock) take it to your local or dealership (not a little freakin'car dealer ship) the ones where you can have it tuned up or fixed.
I have no clue. just hope you stiil have the warranty on the car (doubtful)
Old Jun 29, 2003 | 05:10 PM
Nextelbuddy's Avatar
Default Re: (TrickHonda77)
sounds liek u hydrolocked your motor. when u have a cold air intake and u go through a pudle of water it can suck water into your motor and lock it up. wose case scenario u need a new motor. good luck
Old Jun 29, 2003 | 05:16 PM
Default Re: (nextelbuddy)
Holy crap that does not sound good.
well to start you out on your new engine shopping here's a site: http://www.streetimports.com
Old Jun 29, 2003 | 07:11 PM
b16ej1lsd's Avatar
i'm thinking it's hydrolocked too...
tommarow it's getting towed to a shop, we'll see what they say.
anyone know if this would be covered under insurance? I have full coverage.
Old Jun 29, 2003 | 08:11 PM
2camsaam's Avatar
Default Re: (klear)
sounds hydro'd to me.
try Import Auto Salvage for a new engine.
Best reputation that I am aware of on H-T for engines.
Old Jun 29, 2003 | 08:16 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: (2camsaam)
try this before you tow it, take out the plugs. spin the engine over. re install the plugs. you may have gotten lucky. this happens from time to time.
Old Jun 30, 2003 | 02:55 AM
b16ej1lsd's Avatar
Default Re: (boostedcivicsir)
I tried that already. With the plugs out, the starter solenoid makes a single click, then the lights dim on the dash and then nothing.... it's almost like the starter is jammed er something but that wouldn't explain the code 92
Old Jun 30, 2003 | 05:29 AM
SpyderZEX's Avatar
Default Re: (klear)
Hydro Locked!
Old Jun 30, 2003 | 06:31 AM
mugen76's Avatar
before we jump to conclusions about throwing the motor away... just take off the plugs, take off the EVAP solenoids and other parts on your intake manifold.. leave it in the hot sun to air dry for 3 - 4 days.
Old Jun 30, 2003 | 06:51 AM
LegoZ81's Avatar
Default Re: (mugen76)
klear if you want and it's not at the shop yet gimme a call 830.1980 local number for you I'll take a look at it if you want you. Problems like this usually need eyes to help diagnose.
LMK good luck bro...
Old Jun 30, 2003 | 07:53 AM
jolt-tsp's Avatar
Default Re: (LegoZ81)
Your insurance might cover it if they're lazy. If you feel okay with it, put the intake back to stock before they see it. Not that I would ever do that.
Old Jun 30, 2003 | 08:56 PM
b16ej1lsd's Avatar
Default Re: help! engine wont start (klear)
Old Jun 30, 2003 | 09:01 PM
monicle's Avatar
Holy fried engines Batman!!.. Next time you make some pea soup or lime green coolade you should consider a soup pot or a water pitcher.... not your cylinders.
Old Jun 30, 2003 | 09:06 PM
cash459's Avatar
Default Re: help! engine wont start (monicle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by monicle &raquo;</TD></TR><TR><TD CLASS="quote">
Holy fried engines Batman!!.. Next time you make some pea soup or lime green coolade you should consider a soup pot or a water pitcher.... not your cylinders.</TD></TR></TABLE>
lol...that was funny....but that pic from above makes me want to cry! sorry bro!
Old Jun 30, 2003 | 09:10 PM
civic dx's Avatar
that happend to me when my head gasket blew. i could dry it out and as soon as i turned it over it would fill up with coolant and hydro lock. it did not do any thing to my motor i just needed a new head gasket and it was fine.
Old Jun 30, 2003 | 09:11 PM
b16ej1lsd's Avatar
the coolant is from removing the head
notice the rust on the cylinder walls. tommarow i'll have a better pic of what the intake manifold looked like....there was all kinds of **** in there...
Old Jul 1, 2003 | 06:02 AM
EVIL Hx Coupe's Avatar
Default Re: (klear)
Damn that block looks fucked up....
Old Jul 1, 2003 | 06:57 AM
JdmVetteEater
Guest
Posts: n/a
Damm that looks like ****.... sorry bro.... new motor?
Old Jul 1, 2003 | 07:00 AM
Turbo Powa's Avatar
Default Re: (SpyderZEX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpyderZEX &raquo;</TD></TR><TR><TD CLASS="quote">Hydro Locked! </TD></TR></TABLE>
Old Jul 1, 2003 | 07:05 AM
t0p_sh0tta's Avatar
Default Re: (klear)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by klear &raquo;</TD></TR><TR><TD CLASS="quote">i'm thinking it's hydrolocked too...
anyone know if this would be covered under insurance? I have full coverage.</TD></TR></TABLE>
My friend did the same thing. They totalled the car and cut her a check.
Old Jul 1, 2003 | 12:18 PM
LSpimpTEC's Avatar
DAMN!! Sorry mang. hope everything works out in your favor
Old Jul 1, 2003 | 12:24 PM
Sketch_hs's Avatar
Default Re: help! engine wont start (LSpimpTEC)
swap time!
Old Jul 2, 2003 | 06:35 PM
LegoZ81's Avatar
um #1 should nto be partially down 1&4 should be up when 2&3 are down
