trans internals swap?
Old Jun 29, 2003 | 03:18 PM
JuJuBean's Avatar
Default trans internals swap?
which internals are lighter, stonger, and higher gear ratio? 88 CRX Si trans or the 92-95 Del Sol Si Trans
and next, is it possible to take the internals from the hydraulic manual trans and put them in the crx trans? would it be worth it? am i an idiot?
Old Jun 29, 2003 | 03:24 PM
USDM 4G VTEC's Avatar
Default Re: trans internals swap? (JuJuBean)
well i have worked on D series cable trannies only
i can tell u that the only actual "weak" internals on the Si tranny its the select forks since they are made of aluminum , and the diff pin bc it gets worn out... put a quaife oir some LSD and u will make the tranny a lil stronger...
as far as wich one its better,,,,, MISTA BONE will be able to tell u more about it.... hes the real tranny guru
scoker83
Transmission & Drivetrain
Sep 21, 2014 06:12 AM
xerox445
Classic Hondas
May 23, 2008 01:31 AM
Tyson
10
May 19, 2005 11:01 AM
thegrinch
Mar 24, 2003 02:16 PM
johnzm
Oct 5, 2002 12:15 AM
