rear disc conversion question
Old Jun 29, 2003 | 02:12 PM
98AccordEX's Avatar
Default rear disc conversion question
i did a search and couldnt find anything on this. i got the whole trailing arm assembly from a 92 integra with the e-brake cables. i read that its easier to use the 90-91 CRX SI e-brake cables. do i need them or can i get away with my integra cables? which master cylinder should i get? which proportioning valve should i get? i am getting stainless steel brake lines also. can i just get the whole kit for a 90-91 CRX? or do i need the fronts for an 88-91 Civic and the rears from a 90-93 integra or what? thanks. btw - i have a 90 Civic
Old Jun 29, 2003 | 02:22 PM
bryant's Avatar
Default Re: rear disc conversion question (98AccordEX)
You can use the either brake lines (90-91 CRX Si or 90-01 teg), but since you have the teg ones, those will work fine. As for the MC, you have a lot of options just do a search. SS brakes lines. Just get them for a 90-91 CRX Si.
lrcrx90
Dec 8, 2007 08:16 AM
pac_crx
Jul 15, 2006 05:53 PM
SpoonRex
May 9, 2005 11:19 AM
NAZC
Dec 3, 2002 09:04 PM
1.8Tities
41
Jul 20, 2002 04:08 PM
