B18C1 in EK - Runs Like Poo! No Codes. ??? HELP ??? !!!
Old Jun 29, 2003 | 11:58 AM
Benny Z's Avatar
Default B18C1 in EK - Runs Like Poo! No Codes. ??? HELP ??? !!!
finally got my EK B18C1 hybrid finished.
...but there's one problem...
it doesn't rev up quickly...it kinda lags for a second when you give it throttle, and then slooooooooooooowly climbs up the rpms until vtec, and it picks up a little pace, but still is not right. this happens under load, and in neutral using the finger-throttle control on the TB.
VTEC and IAB both work perfectly and the ECU throws no codes. TPS reads 4.68-4.7 ohm...4.8 ohm is spec.
what could be the problem?
help!
Old Jun 29, 2003 | 02:16 PM
Benny Z's Avatar
Default Re: B18C1 in EK - Runs Like Poo! No Codes. ??? HELP ??? !!! (Benny Z)
anyone?
ideas apprecitaed!
Old Jun 29, 2003 | 07:52 PM
Benny Z's Avatar
ttt
somebody help?
Old Jun 29, 2003 | 07:56 PM
Ivan's Avatar
senior gold member
check to see if all your injectors are firing. and if you're getting spark.
Old Jun 29, 2003 | 08:48 PM
97hb's Avatar
Sound like a clip is switched. I switch the map and tps and it ran horrible with no codes present. I would double check the wiring as 90% of the time the problem is there.
Old Jun 30, 2003 | 03:56 AM
ladysman's Avatar
Default Re: B18C1 in EK - Runs Like Poo! No Codes. ??? HELP ??? !!! (97hb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97hb &raquo;</TD></TR><TR><TD CLASS="quote">Sound like a clip is switched. I switch the map and tps and it ran horrible with no codes present. I would double check the wiring as 90% of the time the problem is there.</TD></TR></TABLE>
Must be more Ghetto wiring there!! Bump
Old Jun 30, 2003 | 04:07 AM
wHOAlly's Avatar
Default Re: B18C1 in EK - Runs Like Poo! No Codes. ??? HELP ??? !!! (ladysman)
check for...
clogged injectors
fouled plugs
crappy/old plug wires
worn distributor cap and roter
proper ignition timing
skipped timing belt
damaged fpr
old/clogged fuel filter
crappy wiring
Old Jun 30, 2003 | 05:22 AM
thinkbrianthink bu's Avatar
drove a t/c'd gsr with the timing belt off by one tooth.
sounded exactly like what your talking about.
Old Jun 30, 2003 | 05:32 AM
Benny Z's Avatar
Default Re: (thinkbrianthink v2)
We've verified that the plug wires are within spec. I'll buy new spark plugs (althought they don't look fouled) and a new fuel filter today.
How will I know if the timing belt is off a tooth?
Old Jun 30, 2003 | 05:44 AM
ladysman's Avatar
Default Re: (Benny Z)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Benny Z &raquo;</TD></TR><TR><TD CLASS="quote">We've verified that the plug wires are within spec. I'll buy new spark plugs (althought they don't look fouled) and a new fuel filter today.
How will I know if the timing belt is off a tooth?</TD></TR></TABLE>
So you checked all the harness wires. You forgot 1 already!!!!
Old Jun 30, 2003 | 07:18 AM
Yougod's Avatar
I'd say check the timing. It's almost always a problem after an engine swap.
Old Jun 30, 2003 | 07:29 AM
b18c1eg
Guest
Posts: n/a
You'll have to pull off the valve cover and see the position of the cam gears when the crank pully mark is lined up with the mark on the t/b cover.
I figured you would have changed the t/b and w/p at the time of the swap. Bring it down here, we'll get it fixed up.
Old Jun 30, 2003 | 07:32 AM
Benny Z's Avatar
Default Re: (b18c1eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18c1eg &raquo;</TD></TR><TR><TD CLASS="quote">
I figured you would have changed the t/b and w/p at the time of the swap. Bring it down here, we'll get it fixed up. </TD></TR></TABLE>
unfortunately, i wasn't planning to do this swap right now (you know that!). so, no, i haven't yet replaced the T/B and W/P. that'll be done as soon as i have my own garage next month. until then, every spare pennie is going to closing costs on the house.
you should come up tomorrow after work to help us troubleshoot.
Old Jun 30, 2003 | 07:44 AM
b18c1eg
Guest
Posts: n/a
I gotta drive an hour south of here tonight to slap a new clutch in a b16 boosted del sol. That'll take probably 3 hours... so I won't get home til late.
I can run up there on the weekend sometime.
Old Jun 30, 2003 | 02:08 PM
LegoZ81's Avatar
The wiring has been checked and checked again the TPS and MAP are connected by their colors listed in the helms.
The fact that the coil the car was running on had over 1 ohm of resistance between A and B and I don't know if the plugs have been checked for proper gap yet. I for some reason think i remember the timing belt being taken off for some reason but can't remember for sure.
Couple more things the fuel in the tank is lower octane then desired, if the timing belt had skipped it would in fact make it behave like this. If that is not the cause, the fact that the distro has been on and off several times w/o the timing being checked/reset with a light or the plugs being checked yet leads me to believe that it is in fact a weak/illtimed ignition system problem being it poor plugs off timing etc.
but hey Ben we'll get this figured out tommorow once we have the needed parts cooL? because with me there and the parts I need we WILL get this done... (I grow impaitent hehe)
Old Jun 30, 2003 | 02:52 PM
Trooper's Avatar
make shure that you are using the INTEGRA injectors and not the civics. They flow the same ammound but the integra injectors are made to rev higher.
Old Jun 30, 2003 | 06:32 PM
wHOAlly's Avatar
Default Re: B18C1 in EK - Runs Like Poo! No Codes. ??? HELP ??? !!! (Trooper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Trooper &raquo;</TD></TR><TR><TD CLASS="quote">make shure that you are using the INTEGRA injectors and not the civics. They flow the same ammound but the integra injectors are made to rev higher.</TD></TR></TABLE>
flow rating is all that matters, 240cc in this case, revs doesnt have anything to do with anything when comparing injectors.
the integra set might be cleaner though becuase they tend to be nwer than civics, therefore making you think they can rev higher
Old Jun 30, 2003 | 06:46 PM
Trooper's Avatar
Ok well call me crazy but on 3 difrent cars I have personaly seen this happen.
99 dx -b16
92 si -LS
97 dx gsr
all of wich have had the civic injectors ran like **** then swaped to integra injectors and made a big ******* difrence.
Old Jul 1, 2003 | 05:59 PM
Benny Z's Avatar
Well, the problem was easy.
The intake-side cam gear had slipped a tooth, advancing the timing I believe 8 (?) degrees.
Once fixed, she runs like a champ.
I'm soooooooooooooo happy to finally have a hybrid again.
WOOHOO!!!
To everyone who helped...
w1ckedboy504
Jan 18, 2010 12:58 AM
B16B_coupe
Jan 2, 2007 10:07 AM
bumbek
10
Dec 11, 2006 08:42 PM
sporty240
Dec 19, 2005 05:21 PM
mugen97ek
Jul 18, 2005 06:50 AM
