88 CRX SI rotor diameter? I can't find it anywhere!
Old Jun 29, 2003 | 09:18 AM
Bontke's Avatar
Default 88 CRX SI rotor diameter? I can't find it anywhere!
I have searched a good bit an can't find a straight answer. I thought that the SI rotors were 10.2" and the stock CRX rotor was 9.5". I was at work and pulled a rotor for an SI and it measured 9.5". I double checked the part number and it was correct. What is the deal? I thought the SI had better brakes than the regular CRX.
Old Jun 29, 2003 | 10:52 AM
95 LS's Avatar
Default Re: 88 CRX SI rotor diameter? I can't find it anywhere! (Bontke)
88-91 CRX SI's have 9.5" front rotors. The 90-91 civic EX has the 10.2" rotors
Old Jun 29, 2003 | 11:20 AM
the DR.'s Avatar
Default Re: 88 CRX SI rotor diameter? I can't find it anywhere! (95 LS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 LS &raquo;</TD></TR><TR><TD CLASS="quote">88-91 CRX SI's have 9.5" front rotors. The 90-91 civic EX has the 10.2" rotors</TD></TR></TABLE>
ditto
Old Jun 29, 2003 | 02:18 PM
Bontke's Avatar
Default Re: 88 CRX SI rotor diameter? I can't find it anywhere! (SlicedBread)
Then what is so special about the brake setup on an SI? Is it because the caliper has a larger piston compared to a regular civic caliper?
Old Jun 29, 2003 | 03:09 PM
Daka's Avatar
The reason that the SI front knukles are wanted is for the reason for fitting other axles when doing swaps. I hope that is what you are looking for!
Daka
whitney
Aug 14, 2013 08:50 AM
s1267712
Jan 22, 2008 10:59 AM
nihad
Apr 2, 2007 08:46 PM
sugarloafpkwy
Dec 17, 2005 03:09 PM
gringo7718
Sep 24, 2004 09:12 AM
