wtf part is this on my suspension
Old Jun 28, 2003 | 11:16 PM
Jonmon's Avatar
Default adjustable swaybar endlinks ?
ok, so i've been messing around with my new digital camera i just got (Canon S50), and so I can finally get around to taking pictures of stuff that I've been wanting to...
what part is this ? and why is it different than on my friend's 2000 GSR ?...... I have a 99
copy and paste links for full size (freakin' 2592x1944)
http://www.imagestation.com/pi...g.jpg
Modified by Jonmon at 2:53 AM 6/29/2003
Old Jun 28, 2003 | 11:21 PM
gsxr's Avatar
Default Re: wtf part is this on my suspension (Jonmon)
that sir is an endlink for your rear swaybar, the one you've got there is not a stock endlink
Old Jun 28, 2003 | 11:26 PM
Jonmon's Avatar
Default Re: wtf part is this on my suspension (gsxr)
it looks adjustable, is it supposed to be ?
also, what makes you think my swaybar isn't 22mm ?
compared to these pics of other 22mm, mine sure does look the same size
besides, i already measured it with calipers, and it sure is 22mm
Old Jun 28, 2003 | 11:54 PM
Jonmon's Avatar
ok, so what are the advantages of an adjustable swaybar endlink ?
Old Jun 29, 2003 | 02:37 AM
xteg95's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jonmon &raquo;</TD></TR><TR><TD CLASS="quote">it looks adjustable, is it supposed to be ?
besides, i already measured it with calipers, and it sure is 22mm</TD></TR></TABLE>
he is saying the endlink isnt stock...not your sway bar. i dont see a reason for it to be adjustable though.
Old Jun 29, 2003 | 07:42 AM
IN VTEC's Avatar
Default Re: adjustable swaybar endlinks ? (Jonmon)
It's probably a Comptech 22mm rear swaybar/lower tie bar kit.
Old Jun 29, 2003 | 09:37 AM
sfr4dr's Avatar
Default Re: adjustable swaybar endlinks ? (IN VTEC)
The adjustable endlink makes it possible to change the preload on the sway bar. By tightening it, the sway bar is effective sooner in it's stroke.
Old Jun 29, 2003 | 09:47 AM
Seedc2's Avatar
Default Re: adjustable swaybar endlinks ? (sfr4dr)
hes right.
check this out if you want to adjust it
http://www.comptechusa.com/instructions/ins023.pdf
Old Jun 29, 2003 | 11:05 AM
Jonmon's Avatar
Default Re: adjustable swaybar endlinks ? (kendogg)
thanks for the link
but my swaybar only has one hole to attach the endlink to, so I'm guessing it's not adjustable ?.........
Old Jun 29, 2003 | 11:47 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jonmon &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the link
but my swaybar only has one hole to attach the endlink to, so I'm guessing it's not adjustable ?.........</TD></TR></TABLE>
it doesn't adjust that way, it adjust by changing the length of the endlink itself. See how it has thread and a lock nut, it's similar to your steering tie rods. You loosen that nut and turn the endlink to make it shorter or longer.
And the ends have heim joints... interesting, never seen that on a swaybar endlink, seems like a good idea.
Old Jun 29, 2003 | 02:00 PM
JDubya's Avatar
sell me your tie bar
civictildeath
28
Jul 13, 2011 08:18 PM
Jasper_db1
Honda Motorcycles
May 20, 2008 10:52 AM
an2ny_858
Jul 10, 2006 12:00 AM
Lo-Buck EF
Sep 5, 2003 07:05 AM
