93 H22A Auto into 96 Accord??
Old Jun 28, 2003 | 09:52 PM
Cottonwoodz's Avatar
Default 93 H22A Auto into 96 Accord??
Anyone of you done this Swap??
JDM Auto H22A into 96 Accord...
Need INFO
Old Jun 28, 2003 | 11:20 PM
ttt
Old Jun 29, 2003 | 12:37 AM
KTeller8's Avatar
Default Re: (Cottonwoodz)
i got the 96 h22 and jdm auto tranny in my 96 accord
Old Jun 29, 2003 | 08:19 AM
SearchBeforeUPost!'s Avatar
Default Re: (KTeller8)
its a complete bolt in, just make sure you get the p13 ecu and tcm. the ecu should be the J-at preferably, but the j-mt will work too...
Old Jun 29, 2003 | 08:22 AM
Default Re: (Bda91acc)
well i just noticed that you have a 96, so you will need to source an obdII engine and ecu. This ecu will have the tcm built in, like your accord one does now. OR you can convert to obdI fairly easily and use the obdI set-up. I am not even sure if a JDM OBDII auto H22 even exists.
Old Jun 29, 2003 | 11:41 AM
CD8's Avatar
CD8
i have this exact swap.
96 accord EX
93 h22a w/ lsd
you need an OBDII-OBDI conversion harness...
use accord mounts, except for the driver's side prelude mount.
you need to run a couple wires... cant remember exactly which ones but vtec solenoid and such... check http://www.h22a.org for more info.
if your keeping the car auto, then you need the auto ecu, if your going to manual you need the manual ecu and manual tranny of course
Old Jun 29, 2003 | 07:15 PM
Default Re: (CD8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CD8 &raquo;</TD></TR><TR><TD CLASS="quote">i have this exact swap.
96 accord EX
93 h22a w/ lsd
if your keeping the car auto, then you need the auto ecu, if your going to manual you need the manual ecu and manual tranny of course </TD></TR></TABLE>
So the OBDII-OBDI conversion harness will work for a Auto?
Old Jun 29, 2003 | 08:26 PM
KTeller8's Avatar
lol, its going to get more complicated then that: the obd1 harness is really really weird:
But it can be done, and only one person/place i know of will do it:
email me: i have a direct contact with them
Old Jun 29, 2003 | 09:43 PM
CD8's Avatar
CD8
that the same place you got me my harness from? cus i had to change a couple wires on that one... some of the soldering was very suspect
Old Jun 29, 2003 | 09:50 PM
GimpyAccord's Avatar
Default Re: (CD8)
Looks like its been pretty well covered but: you're gunna have to either goto OBDI or convert the engine to OBDII. You'll be missing some small items like a CKF sensor etc. When I used to do swaps I'd generally TRY to keep obdI engines with odbI cars etc... more for possible smog inspection situations than anything. Otherwise its a straight forward swap.
Be wary of a lot of those OBDII -&gt; I conversion harnesses. Many of the ones I've used use shoddy connectors and are missing KEY **** like RPM output, EGR and other really annoying things... lucky for me I have a mad stash of pushpins y0
Old Jun 29, 2003 | 10:16 PM
KTeller8's Avatar
Default Re: (CD8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CD8 &raquo;</TD></TR><TR><TD CLASS="quote">that the same place you got me my harness from? cus i had to change a couple wires on that one... some of the soldering was very suspect </TD></TR></TABLE>
no we dont use them anymore: we had major issues with them after that:
and its a lot more complecated: With yours it was simple obd2-1:
this will be from a one ecu system to rewirign the tranny and ecu to use two sperate systems; The tranny will have to be rewired to read a TCU/TCM and the car to run off a ECU: Your looking at almost twice teh conversion:
the guy spent 4 hrs at honda trying to figure out, how to figure out the obd2 tranny to rewire it to run all by itself!
No one will do a auto to auto, that i know of cause of this hassle: I asked around for six months: before i got him to finally go and do it for me
Old Jun 29, 2003 | 10:19 PM
KTeller8's Avatar
Default Re: (GimpyAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GimpyAccord &raquo;</TD></TR><TR><TD CLASS="quote">Looks like its been pretty well covered but: you're gunna have to either goto OBDI or convert the engine to OBDII. </TD></TR></TABLE>
still wont help making it obd2: cause there is NO USDM Honda Auto H22 Vtec ecu:
and you really cant use a 97+ cause they contain the immoblizer as well came with the sport shift option: not a true automatic:
you can get a obd2 jdm ecu: If you happen to have a few months to search: ive called every jdm seller on this site and several others, NO ONE was able to locate an auto jdm ecu for me:
Even accord94dx, Brian, was over in JDM land for several months: he only saw 3 ludes the whole time: None in junkyards and none anywhere else,
believe me, get this special harness or go five speed: only two options:
Old Jun 29, 2003 | 10:41 PM
ooooh you're not thinking out of the box mon... and I don't talk anymore unless im getting paid
Old Jun 30, 2003 | 05:20 AM
carolinaACCORD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KTeller8 &raquo;</TD></TR><TR><TD CLASS="quote">lol, its going to get more complicated then that: the obd1 harness is really really weird:
^ Or you can have patience like me and do the wiring yourself.
Old Jun 30, 2003 | 05:28 AM
Default Re: (carolinaACCORD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carolinaACCORD &raquo;</TD></TR><TR><TD CLASS="quote">
^ Or you can have patience like me and do the wiring yourself.</TD></TR></TABLE>
yeah I remember Wadzii made his own harness, his passenger floorspace was literally a rats nest of wires
Old Jun 30, 2003 | 07:34 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bda91acc &raquo;</TD></TR><TR><TD CLASS="quote">yeah I remember Wadzii made his own harness, his passenger floorspace was literally a rats nest of wires</TD></TR></TABLE>
LOL. Well, I'm hoping for mine to be a little neater than that.
Old Jun 30, 2003 | 07:41 AM
LOL. Well, I'm hoping for mine to be a little neater than that.</TD></TR></TABLE>
nahh man; function over form, isn't that how it goes?
trequartista_10
Sep 11, 2012 08:28 PM
dougb77
Aug 16, 2005 11:18 AM
accordlude
Jan 22, 2004 09:18 AM
prjctCIVIC
Jun 14, 2002 05:34 AM
