what's the difference between koni yellow.. and neuspeed koni yellow???
I
to Smooch Pickle
to Smooch PickleJoined: Jun 2003
they are different prices on importhorizon.. koni yellow are just $510, wheras the neuspeed koni yellows are $535. are they better?? and are they worth the extra?? thanks
the neuspeed specs have two additional perches to the 3 that are on the standard koni yellows, so there are 5 in the approximate space that the 3 usually take up. (one in between where each standard koni perch is)...
the shock body is also slightly shorter for greater shock travel...
if the above reasons justify your $25 is up to you
the rod is 20mm shorter giving u more travel without bottoming out...tornactive.com has great deals on them...best that i have seen
I
to Smooch Pickle
ok.. how come on tornactive.com, the koni yellows are for sale for $141 or $564 for 4 and the neuspeed/koni yellows are cheaper... for $135 or $540 for 4!!! but on importhorizon, the neuspeed/koni is more expensive??
IF i worked at Import Horizon I would be able to answer your question but I DON'T. You're best bet would be talking to someone who works there. Try calling them or something.
tornactive deals maninly with koni's period and he has the yellows for a great deal....talk to rob from tornactive...he's a nice guy...also who gives a **** if u pay less for one place...isnt that what ur looking for??? lol
integranator
Nov 15, 2002 01:05 PM
