Knocking noise when i turn.
Old Jun 28, 2003 | 08:21 PM
THE GAME IS THICK's Avatar
Default Knocking noise when i turn.
When i turn my wheel when im moving around 5mph o hear a knocking noise coming from my passenger side wheel well it sounds like a double knock when i turn but it doesnt sound like a clicking noise an axle would make... i sounds really annoying im guessing its the steering rack maybe?
Old Jun 28, 2003 | 08:27 PM
function83's Avatar
Default Re: Knocking noise when i turn. (igotsol!)
check your axles.......your outer cv joints are probably goin out.
Old Jun 28, 2003 | 10:04 PM
Shreik's Avatar
agreed, sounds like your CV joint. i just changed my pass. side axle. That axle nut is a bitch, i messed up my hand tryin to use a breaker bar. i ended up paying a garage to loosen mine with an impact gun. If ur gonna change it yourself check out this thread https://honda-tech.com/zerothread?id=382416
very good tutorial
Old Jun 28, 2003 | 10:30 PM
EtotheG's Avatar
agreed... check ur cv.. my friends car made the same noise when his went out
Old Jun 29, 2003 | 12:58 AM
TuCKiNaLL4s's Avatar
cv for sure....not that much to replace
Old Jun 29, 2003 | 01:48 AM
Robo_Wop's Avatar
My car is doing the exact same thing...
but what causes the CV joint to wear out...i've already broken the axle in half.
cause my Dad is probably gonna find a way to either blame it on my rims, tires, or smoke shows.
Old Jun 29, 2003 | 07:03 AM
jaxle's Avatar
CV Joints wear out when the boot holding all the grease gets torn allowing dirt and other crap to screw up the joint. Bigger rims over stock would stretch the boot farther b/c the axle is at a greater angle than with stock wheels. This could allow it to wear faster i guess.
Old Jun 29, 2003 | 07:45 AM
f1uxx's Avatar
cvjoint
Old Jun 29, 2003 | 08:05 AM
Doeboy's Avatar
agreed, cv joints are going bad
Old Jun 29, 2003 | 11:30 AM
Status Sean's Avatar
momst likely a cv joint on the axle
Old Jun 29, 2003 | 12:04 PM
Damon's Avatar
Default Re: (jaxle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaxle &raquo;</TD></TR><TR><TD CLASS="quote">Bigger rims over stock would stretch the boot farther b/c the axle is at a greater angle than with stock wheels. This could allow it to wear faster i guess. </TD></TR></TABLE>
did you make that up, or did someone tell you that and you believed them?
Old Jun 29, 2003 | 12:14 PM
JSPECEX's Avatar
Default Re: Knocking noise when i turn. (Robo_Wop)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Robo_Wop &raquo;</TD></TR><TR><TD CLASS="quote">My car is doing the exact same thing...
cause my Dad is probably gonna find a way to either blame it on my rims, tires, or smoke shows.</TD></TR></TABLE>
your dad is right that is usaully why they break to big of rims or just luanching bad. i broke one axle in half and just recently messed up my cv joint
Old Jun 29, 2003 | 12:15 PM
JSPECEX's Avatar
Default Re: (Damon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Damon &raquo;</TD></TR><TR><TD CLASS="quote">
did you make that up, or did someone tell you that and you believed them?</TD></TR></TABLE>
hes right
iwanaturboteg
Apr 29, 2008 11:16 AM
phoshyzzle
Apr 12, 2008 01:13 PM
whp
Feb 3, 2007 08:08 AM
GReddy SI
12
Dec 21, 2003 12:14 AM
Stellar1
25
Mar 11, 2003 05:35 PM
