What kind of torch did you use to bend your valve adjustment wrench..
Old Jun 28, 2003 | 05:34 PM
Pineapple Devil's Avatar
Default What kind of torch did you use to bend your valve adjustment wrench..
I'm doing it tomorrow. Is propane enough?
Old Jun 28, 2003 | 05:45 PM
koco's Avatar
Default Re: What kind of torch did you use to bend your valve adjustment wrench.. (Pineapple Devil)
I didn't need a torch. I just locked the wrench in my vise and used a pipe to bend it. It was a cheap wrench, but it dosen't require a really high quality one. It took 10 minutes to complete the transformation.
Old Jun 28, 2003 | 06:03 PM
Default Re: What kind of torch did you use to bend your valve adjustment wrench.. (koco)
how close to the opening did you put the vise? i'm afraid i'll alter the opening and it wont be 10mm anymore
Old Jun 28, 2003 | 09:39 PM
Westrock2000's Avatar
Maybe you could torch in a LS motor...then you wouldn't need a special tool
Old Jun 30, 2003 | 11:12 AM
koco's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pineapple Devil &raquo;</TD></TR><TR><TD CLASS="quote">how close to the opening did you put the vise? i'm afraid i'll alter the opening and it wont be 10mm anymore</TD></TR></TABLE>
The wrench was placed about 1 1/2 inches from the end. The open end side of it was covered by the vise clamps with the handle sticking out. It won't change the size of the opening. The wrench should be in the vise right where you want it to bend. Kinda hard to splain it.
g-ride-si
12
Sep 28, 2005 04:09 PM
DB8_TEG
Nov 16, 2003 11:14 AM
fe519
Jul 3, 2003 07:03 AM
BrandonClaps
Apr 21, 2003 06:19 AM
goforbroke
May 14, 2002 12:48 AM
