Rotor over hub swap a success on a 5th gen
Old Jun 28, 2003 | 04:30 PM
TypeSH's Avatar
Default Rotor over hub swap a success on a 5th gen
Ahh, 2 days, 1 broken breaker bar, a rusted axle/hub and many cuts and bruises later, everything works.
I've driven a few miles to run errands and everything seems perfect. No issues, no clearance problems, and I'm running 7 spoke accord wheels. So w/ gimpy doing this on a 4th gen and everythign looking fine for my 5th gen, it looks like it will work for all 90-97 accords (except v6 models)
I used 98-99 2.3 CL hubs, 3.0 CL rotors, 3.0 CL calipers, 5th gen accord wheel bearings.
-edit-
forgot to insert the 2.3 CL hubs, NOT 3.0 ones which will NOT work.
Modified by TypeSH at 5:34 AM 6/30/2003
Old Jun 28, 2003 | 06:42 PM
SearchBeforeUPost!'s Avatar
Default Re: Rotor over hub swap a success on a 5th gen (TypeSH)
I know alot of peeps will be happy with that news.
How did you break the breaker bar? axle nut?
Old Jun 28, 2003 | 08:06 PM
GZERO's Avatar
what size of rotors?? 11.1 or 11.8?
Old Jun 28, 2003 | 08:22 PM
Accord94DX's Avatar
cl calipers work with the accord bracket?
Old Jun 28, 2003 | 09:50 PM
f22a's Avatar
are the 98-99 CL's 5-lug?
Old Jun 28, 2003 | 11:52 PM
TypeSH's Avatar
Default Re: (f22a)
yep, axle nut broke it. I couldnt budge it so i slaped a 5 ft pipe over it, snapped it at the attachment.
rotors are 11.1" .I odnt know of any 4 lug 11.8" rotors, only the 5-lugs (RSX-S, CL-S, TL-S) seem to have them.
stock accord brakets will not work, they are designed for 10" rotors. Although many, many 11" brackets will work, or they area really the same (4th gen lude, believe 5th gen ludes should work, 2nd gen legends, 5th gen accord wagons/v6's, acura 3.0 CL's etc).
98-99 CL's are 4x114.3. TL's were 5 lugs. they switched to 5 lug in 2001 for hte CLs.
Old Jun 29, 2003 | 06:23 PM
GimpyAccord's Avatar
Default Re: (TypeSH)
good job dood
YossarianLives!
Jun 9, 2007 10:11 PM
LDYKLLA
Apr 29, 2004 01:45 PM
Superorb
Jun 2, 2003 04:09 PM
see_fu
Aug 28, 2002 07:29 AM
TWG
May 23, 2002 11:16 AM
