how to install indiglo gauges in a 90 crx si??????
Old Jul 26, 2001 | 12:17 PM
RICEBURNER1406's Avatar
New User
Default how to install indiglo gauges in a 90 crx si??????
anyone know how to install these gauges???? do i have to take out the stock gauges? the damn thing didnt come with instructions. someone please shed some light here? thanks
Old Jul 26, 2001 | 01:58 PM
Chris_'s Avatar
Default Re: how to install indiglo gauges in a 90 crx si?????? (RICEBURNER1406)
I have semi detailed instructions on my web site http://www.crxconnection.com
in the tech data section under electronics
here is a direct link
http://www.angelfire.com/mi3/crxconnection/tech/electronics/indiglo/indiglo001.htm
Old Jul 26, 2001 | 02:04 PM
New User
Default Re: how to install indiglo gauges in a 90 crx si?????? (crxconnection)
THANKS MAN I APPRECIATE IT, BUT WHAT DO I USE TO PRY THE NEEDLES OFF?
Old Jul 26, 2001 | 07:53 PM
Dru-Si's Avatar
Which ones did you get? You shouldn't have to remove the needles at all. They should slip over the needles.
Old Jul 27, 2001 | 01:55 AM
B16CRX's Avatar
Default Re: how to install indiglo gauges in a 90 crx si?????? (Dru-Si)
Yeah, most should slide over the needles. If yours won't, you can use a fork to pull them off. Do it very carefully and put them back in exactly the same spot.
Old Jul 27, 2001 | 05:56 PM
nawoj's Avatar
Default Re: how to install indiglo gauges in a 90 crx si?????? (B16CRX)
step 1.
DONT BE A IDIOT!
i was when i tried to install the indiglos i got for x-mas.
i ended up breaking off the tach support needle and now my tach is all screwed up!
[tach says im idling at 0!]
well now that i fiddled with it more now it says its idling at 1300... damnit!
should be at 700.
IF EVERYTHING DOSNT MATCH DONT FORCE IT!
doubleecho
Jul 16, 2007 09:30 AM
jsteezy1290
23
Jul 16, 2004 03:53 PM
vannman
May 24, 2004 06:49 PM
acme
Jun 6, 2002 04:20 PM
