DA integra seat belt stuck!!.. help!
the power seat belt is stuck.. it wont go back wen i put my keys... when the keys are put in theres no beep sound coming frm the dash.. wat can cause this? wat should i check?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ambiguousasn »</TD></TR><TR><TD CLASS="quote">seatbelts are under a lifetime warranty from the dealership. bring the car in and see what they can do </TD></TR></TABLE>
hey thats good to know.
is this true for all cars? hodnas? integras?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wizzards581 »</TD></TR><TR><TD CLASS="quote">r u sure its lifetime warranty? has it happen to u?</TD></TR></TABLE>
he is correct. i took my old DA with the same prob to a local acura dealership. they fixed it free of charge!
safety restraint items, such as seatbelts, are covered under a lifetime warranty as mandated by the federal government and d.o.t. this is true for any car. take it to the dealership and make sure they honor that. also, there may be a note of it in your owner's manual. heck, even the factory muffler is covered under a lifetime warranty
i release the buckle in and out.. no sound from the dash.. my keys are on acc or on and theres no beeping sound from the dash.. all fuses are checked already thats why im here. i dont think the seat belts has fuses.. haha....
like the other's said, take it to acura, its under lifetime warranty. I've had mine fixed there before. its nice to have a lifetime warranty, but man, i hate dealing w/ the dealership, all they do is waste my time! grr.
is it just one seatbelt or are both not functioning?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91IntegGS »</TD></TR><TR><TD CLASS="quote">like the other's said, take it to acura, its under lifetime warranty. I've had mine fixed there before. its nice to have a lifetime warranty, but man, i hate dealing w/ the dealership, all they do is waste my time! grr.
is it just one seatbelt or are both not functioning?</TD></TR></TABLE>
for me, htey replaced both for free even tho the drivers side was broken.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote"> i dont think the seat belts has fuses.. haha....</TD></TR></TABLE>
Think that's pretty funny huh? Did it ever occur to you that there is a motor that drives the seat belt? Or did you just think it was magic?
im sure the seat belts are probably hooked up to the ignition which it doesnt have its own fuse.
actually my seat belt didnt die while im driving.. it died after the door was opened so you dont want to be driving with ur seat belts up front... its annoying.. and yes it would b better if it died while driving..but it didnt.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ambiguousasn »</TD></TR><TR><TD CLASS="quote">seatbelts are under a lifetime warranty from the dealership.</TD></TR></TABLE>
the seatbelts are a lifetime warranty, as long as the car doesn't have a salvage title.
theres no fuse for seat belts... there are for doors... power windows worked fine. everything else for the doors worked. even the door lights lite up on the dash and the door lamp works too...
its a salvage title integra though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wizzards581 »</TD></TR><TR><TD CLASS="quote"> its a salvage title integra though.</TD></TR></TABLE>
you could still try, just hope they won't run a VIN check on your car...
there are fuses for the seat belts, and you can move them from the front to the back. you have to manually crank it back. there is a hole that you pop the cover off and crank it back. i had to do it on mine, and the control box for the seat belts is on the floor by the computer. remove the plastic on the right and it is behind that. hope this helps.
Mine is sturck too.. I just called Acura of Brookfield Wisconsin, and the guy told me there was only a 60,000 mile warrantee against the seat belts, but he also told me to clean out the tracks and lube it up and it should be fine.
DSMpolska
Sep 15, 2008 04:24 PM
fastball777
Jun 23, 2004 12:52 PM
but did you try releasing/reinserting the buckle? sometimes mines stops halfway and releasing/reinserting the buckle fixes it.
freakin
