!!!!!cam install last leg -questions !!!!HELP!!!
Old Jun 28, 2003 | 10:23 AM
216.226.142.95:27016's Avatar
Default !!!!!cam install last leg -questions !!!!HELP!!!
ok cam, cam plates, and caps are on, now the timing belt is giving me problems. how do i slip that dam thing on? im trying to get to the tension bolt but the lower timing belt is covering it, how can i remove it? i dont want to have to take off the crank bolt since i dont have tools to torque that thing back on
last, how do i make sure the engine is truly at TDC since it could have moved a bit during the installation.
Old Jun 28, 2003 | 10:42 AM
ciRcuitJerk's Avatar
jus f0 dekarayshunZ
Default Re: !!!!!cam install last leg -questions !!!!HELP!!! (216.226.142.95:27016)
your doing a cam install but you dont know how to find tdc what kind of car are you doing it on..what engine??
Old Jun 28, 2003 | 11:05 AM
tilt's Avatar
you can slip the timing belt on just keep at it or get a friend to help. If you really have to, there should be a rubber plug on the tbelt cover, pop it off and you have access to the tensioner bolt.
As for making sure it's timed right, you should have made white marks on the belt referencing the dots on the cam gears, you dont even have to think about if it's on right or not. since you didnt just line up the inner dots on the camgears and make sure the crank is tdc.
Old Jun 28, 2003 | 11:14 AM
P1mpSlap's Avatar
you have to use the cam holder holes, slip a 8mm punch (I think that's the size) down into the holes to lock the cams in place at TDC.
You will prolly need 2 people to do this. Then have someone hold the cams and punch in place. Then you pull the timing belt over the cams.
Dude consult the helms manual. The cam install should've only taken about 2-3 hours max.
Old Jun 28, 2003 | 11:32 AM
Default Re: !!!!!cam install last leg -questions !!!!HELP!!! (ciRcuit_ _ _)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ciRcuit_ _ _ &raquo;</TD></TR><TR><TD CLASS="quote">your doing a cam install but you dont know how to find tdc what kind of car are you doing it on..what engine??</TD></TR></TABLE>
i know how to find TDC, i just want it to be exact or nearly close to it. i aligned the small notches up horizontaly with the arrows pointing up pior to removing the cams. i know how to install cams i just need reassurance and welcoming other methods. so back at you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tilt &raquo;</TD></TR><TR><TD CLASS="quote">there should be a rubber plug on the tbelt cover, pop it off and you have access to the tensioner bolt.
really? ill look for this, im getting ready to hack off the tbelt cover if i cant get it off properly.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tilt &raquo;</TD></TR><TR><TD CLASS="quote">As for making sure it's timed right, you should have made white marks on the belt referencing the dots on the cam gears, is tdc. </TD></TR></TABLE>
i did this with tape and a black marker but the problem is i cant slip the belt back over the cam gears thats why i want to access the tension bolt. i also checked with sparkplug hole #1 if the piston is up top, which it is.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P1mpSlap &raquo;</TD></TR><TR><TD CLASS="quote">you have to use the cam holder holes, slip a 8mm punch (I think that's the size) down into the holes to lock the cams in place at TDC.
Dude consult the helms manual. The cam install should've only taken about 2-3 hours max.</TD></TR></TABLE>
ill try the punch method but im doing this alone in the wee hours between when my dad's not home because according to him everything i do with the car is ******* it up, i dont like confrontations.
i also have a helms but its for a 94 model so there might be slight diffrences.
ANYMORE SUGGESTIONS?
how about how to access the markings on the block without taking off the crank bolt?
Old Jun 28, 2003 | 03:06 PM
&lt;---- frustrated as ****!
for some reason the timing belt is too tight!
power steering sytem/tank, cruise control and part of the driver side engine mount is off!!!! im going to hack the tbelt cover to get to the tension bolt!
Old Jun 28, 2003 | 03:19 PM
P1mpSlap's Avatar
Dude, it is going to be BITCH *** tight. That's why you need 2 people to pull it back on.
It's easy as hell to slip that thing off. It's one of the hardest parts to pull it back on.
The 94 Helms manual will tell you EXACTLY how to install the cams. It's not different in any way.
Old Jun 28, 2003 | 03:23 PM
Default Re: (P1mpSlap)
ahhh **** i dont think i can ask my mom to spot me, she has atrithis.
fawking A!!!!!!!
Old Jun 28, 2003 | 03:40 PM
P1mpSlap's Avatar
Default Re: (216.226.142.95:27016)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 216.226.142.95:27016 &raquo;</TD></TR><TR><TD CLASS="quote">ahhh **** i dont think i can ask my mom to spot me, she has atrithis.
fawking A!!!!!!!</TD></TR></TABLE>
bwhhahahahahahhahahhahha
Old Jun 28, 2003 | 04:14 PM
be nice if i can just "HULK" out and put the timing belt on
inputs are welcome
Old Jun 28, 2003 | 05:55 PM
95 Gizzer
Guest
Posts: n/a
Try taking off the plates and lifting the cam so its at an angle, and then put it on. I remember doing that when I did my cam install. It was a bish
masospaghetti
Jun 26, 2016 05:45 AM
EF'GSRrr91
Jan 20, 2015 12:48 PM
boost hep
Mar 25, 2007 04:02 PM
skata89
Dec 19, 2006 09:03 AM
Exempt
Apr 7, 2005 09:53 AM
