question about the skunk2 short shifter
Old Jun 28, 2003 | 09:23 AM
Loveless's Avatar
Default question about the skunk2 short shifter
see the nut on top? that's as far as it'll go and it doesn't look very secure
Old Jun 28, 2003 | 09:25 AM
ImportHatch's Avatar
Default Re: question about the skunk2 short shifter (Loveless)
Is the nut the right thread pitch for the shifter??
Yager-
Old Jun 28, 2003 | 09:38 AM
DUCK COMMANDER's Avatar
Default Re: question about the skunk2 short shifter (ImportHatch)
its a lock nut. It has some kind of plastic on the end. You can't hand tighten it unless your the Hulk. Use a wrench and it will tighten.
Old Jun 28, 2003 | 09:50 AM
Spoodge's Avatar
From: Slut City aka San Diego, Ca, United State Of King
use a lock washer too.. plus a few washer , so there is no rattle
Old Jun 28, 2003 | 10:38 AM
Loveless's Avatar
Default Re: (SpoodgeDc2)
thanks
Modified by Loveless at 6:01 PM 6/28/2003
Old Jun 28, 2003 | 02:43 PM
Mark's Avatar
*Bounty Hunter*
Default Re: (Loveless)
dont mean to thread jack, but my skunk2 SS likes to bang against my N1 piping :\
anyone else have this problem?
Old Jun 28, 2003 | 02:52 PM
Loveless's Avatar
theif!
I have greddy sp and doesn't seem to have this problem. Yes I know it's not an N1.
After the install I thougth I screwed something up because it wouldn't move, turn out that it's just stiff. Speaking of bushing, I couldn't get the ring bushing connected to the transmission to go in.
I even tried to grease it
here is an install blooper picture. I thought that's where it goes.
Old Jun 28, 2003 | 03:50 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
There should be little washers or something in addition to the spacer, that should go on each side of the bearing in the shifter that prevents you from overtightening it. Since it has the bearing it will still be able to move no matter how much you tighten it. That's how it is w/ my generic shifter.
Also the actual shift linkage fork will take up some more space on that bolt.
br8crumb
Jan 15, 2017 07:06 AM
jonnyt1130
Transmission & Drivetrain
Oct 6, 2009 07:14 AM
dabigshmo
Oct 15, 2007 11:52 PM
SupaTegRS
Apr 30, 2003 06:07 PM
