no search results: flywheels torque specs?
bolting flywheel, pressure plate and tranny all back together.
does anyone know the torque specs?
so far i have 24ftlbs on the pressure plate. is this right?
torque on flywheel?
torque on tranny? i was told when bolting the tranny back on that not all the bolts have the same torque setting is this correct?
i'll be starting in a few hours (10:21 on west coast right now). any help would be appreciated. thanks.
*edit*
GSR tranny. sorry to be so vague. thanks, Maztur
Modified by kaj at 10:47 AM 6/28/2003
Modified by kaj at 10:48 AM 6/28/2003
torque on flywheel?
*edit*
any truth to what i was told about the trans being bolted back on? all bolts have the same torque specs? if so what is it? if not, what are the specs for which bolts?
if they are all different, this will be a hard question to answer.
*edit*
thanks for the pp/flywheel info!
Modified by kaj at 12:51 PM 6/28/2003
*edit*
