FS: TurboXS Blow off valves
Old Jun 28, 2003 | 07:39 AM
gigantor's Avatar
Default FS: TurboXS Blow off valves
The first one is the Type-S BOV ($75 shipped):
The TurboXS Blow Off Valve - Type S is designed to release compressor pressure surge caused by changing gears or backing off the throttle quickly. This valve is an extremely important part of any turbo system allowing quicker turbo spool up between gear changes and greatly increasing the life of a turbocharger. The BOV Type S is recommended for small to medium sized turbo charged engines running up to 15 psi boost. Each valve is individually tested to hold 30 lbs. of boost.
Sizing of valve is based on flow and not boost pressure.
Then we have the Type-FRL (real ******* loud!) ($100 shipped):
The redesigned Type H-RFL is for high performance applications with the desire to be noticed! If you need to ask this valve is too loud for you! A new larger billet aluminum body and a beefier piston ensures the valve remains smooth under the most demanding circumstances. This valve relieves compressor pressure surge caused by changing gears or backing off the throttle quickly and is designed for turbo charged engines running up to 25 psi boost.
Old Jun 28, 2003 | 01:46 PM
domanicivic's Avatar
i want the RFL. i got first dibs.. lol
email me. carlo_sebastian@yahoo.com
Old Jun 29, 2003 | 05:42 AM
gigantor's Avatar
Default Re: FS: TurboXS Blow off valves (gigantor)
ttt
Old Jun 29, 2003 | 09:27 AM
gigantor's Avatar
RFL is one. Type-S is still for sale!
Old Jun 30, 2003 | 04:06 AM
gigantor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gigantor &raquo;</TD></TR><TR><TD CLASS="quote">RFL is one. Type-S is still for sale!</TD></TR></TABLE>
Old Jun 30, 2003 | 08:13 AM
gigantor's Avatar
bump
Old Jul 1, 2003 | 03:56 AM
gigantor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gigantor &raquo;</TD></TR><TR><TD CLASS="quote">The first one is the Type-S BOV ($75 shipped):
This one is still available!
bboygreddy
Jul 10, 2007 06:41 AM
CivicT
Nov 18, 2004 01:54 PM
Happyman
Nov 14, 2003 06:18 PM
darksideracing
Oct 3, 2002 07:09 PM
