Jdm B18C. What fuel pressure?
Old Jun 28, 2003 | 06:48 AM
speedymon's Avatar
Default Jdm B18C. What fuel pressure?
Got a B18C gsr block on a USDM gsr head. Stock injectors. What fuel pressure should i run in this 10.6 compression motor? Oh please specify with vac line on or off. Thanks
Old Jun 28, 2003 | 06:51 AM
eg6ajk's Avatar
Default Re: Jdm B18C. What fuel pressure? (speedymon)
stock pressure is about 40psi (+-3psi) at idle
Old Jun 28, 2003 | 09:02 AM
speedymon's Avatar
Default Re: Jdm B18C. What fuel pressure? (eg6ajk)
Hmmm. 37-43 psi with the vac line on at 10.6:1 compression? Thought that was kinda low.
Old Jun 28, 2003 | 10:22 AM
tilt's Avatar
yeah it is about 40-43 psi with the vac tube on a usdm engine. might want to bump it up just a tad for the 10.6 compression.
Old Jun 28, 2003 | 11:34 AM
eg6ajk's Avatar
Default Re: Jdm B18C. What fuel pressure? (tilt)
its the same as USDM engine. no difference, .6 in compression makes no difference in overall fueling the point where totally differnet fuel pressure or maps are really required.
Old Jun 28, 2003 | 12:10 PM
MikeSarr_GSR's Avatar
the maps are different. fuel pressure on USDM and JDM B18C should be the same.
one5oh2nv
Feb 6, 2007 12:08 AM
Chubz
Aug 28, 2004 06:58 AM
XSlackerX
Nov 26, 2003 04:08 PM
98civicEX
Feb 18, 2003 09:37 PM
