Legend/ NSX Calipers on 99 Civic Si ???
Old Jun 28, 2003 | 12:35 AM
NXSpoon's Avatar
Default Legend/ NSX Calipers on 99 Civic Si ???
I have seen all the previous posts re: ITR's upgrading to Legend / NSX calipers and running either Legend or Prelude rotors. My question is: Has anyone done this on their 96-00 Civics?? I am running 4 X 100 and do not plan to change to a 5 lug any time. So, would I need just Brembo blanks drilled to 4 X 100?? From what car should the blanks be from?? Prelude VTEC??
Also, will the NSX calipers bolt onto the Civic, or will there be some shimming involved, etc.??
Old Jun 28, 2003 | 01:57 AM
.RJ's Avatar
.RJ
Default Re: Legend/ NSX Calipers on 99 Civic Si ??? (NXSpoon)
The big reason for going to legend/nsx calipers on ITR's is because of the thicker rotor you can now use. Thicker rotor = more mass = bigger heat sink = less fade at the track (road courses).
if you could drill the rotors, or somehow found a 4x100 rotor w/ the right dimensions it could probably work w/ some custom brackets made.
The fastbrakes kit would be a better alternative for you if you have a necessity for big brakes - which most people dont - good pads/fluid/brembo blanks should be all you need.
Old Jun 28, 2003 | 05:03 AM
NXSpoon's Avatar
Default Re: Legend/ NSX Calipers on 99 Civic Si ??? (.RJ)
The Fast Brakes kit you are referring to is the 11 in version?? W/ the Wilwood calipers?? Are those rotors wider as well as larger in diameter??
Modified by NXSpoon at 9:17 AM 6/28/2003
superdelsol
Jun 4, 2007 08:34 AM
Jordan_4WS
Oct 24, 2006 01:02 AM
drunknbass
12
Feb 19, 2004 04:50 AM
GoldenONE
May 16, 2003 11:43 PM
2000si
Mar 12, 2002 10:37 PM
