need help go hesitation
Old Jun 27, 2003 | 04:43 PM
tdc's Avatar
tdc
Default need help go hesitation
ok its a 92 gsr and its got a desitation somtimes when i take off and slow down then take off agian (like if your making a right hand turn and not slow enuff for 1 st and to slow for 2nd)also some times it won`t strart up ti takes 2 or 3 trys before it starts .. any idea`s where should i start ... just so you no ..there`s no code flashing
Old Jun 27, 2003 | 06:06 PM
Loveless's Avatar
Default Re: need help go hesitation (tdc)
it's easy to type when you disregard grammar, punctuation and spelling
Old Jun 27, 2003 | 06:48 PM
Neukin's Avatar
Default Re: need help go hesitation (Loveless)
typing wouldnt be any fun if you had to do all that i have the same problem with my car sometimes 2
Old Jun 27, 2003 | 08:15 PM
King_j's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tdc &raquo;</TD></TR><TR><TD CLASS="quote">ok its a 92 gsr and its got a desitation somtimes when i take off and slow down then take off agian (like if your making a right hand turn and not slow enuff for 1 st and to slow for 2nd)also some times it won`t strart up ti takes 2 or 3 trys before it starts .. any idea`s where should i start ... just so you no ..there`s no code flashing</TD></TR></TABLE>
sounds like you need a tuneup. how old are the plug wires? plugs? cap and rotor? clean the injectors with a fuel system or injector cleanor.
if you have already done all of this, then what are you idling at?
slammedz6ef
Dec 6, 2007 12:36 AM
sii.
Jan 29, 2007 10:24 PM
rohec04
Nov 16, 2005 09:19 AM
billybong91DA
Feb 6, 2004 01:08 PM
