Squeeking Noise.... Suspension?
When i'm driving and i hit bumps i'm getting a squeeking noise which appears to be coming from outside of the vehicle.. I'm thinking it's coming from the suspension. What should i check or lubricate?
I had the same problem. I figured it was the Delrin bushings I have up front, so I greased the hell out of them. Seemed to help a little. Then I installed a c-pillar bar and the squeaks are gone.
you probably have a worn out bushing. Put the car on jackstands, and run each tire through its range of travel w/ a floor jack. You should be able to pinpoint the noise(s) this way.
akteamster
Nov 18, 2004 07:48 PM
