Correct way to primer urethane?
Old Jul 26, 2001 | 06:30 AM
WuShu's Avatar
New User
Default Correct way to primer urethane?
First off i know , i know this should be in cosmetics, i already put it in there, reason im asking you guys is cuz lots of you have urethan kits and maybe you saw how they painted your cars and i know a lot of you guys know alolt about bodywork. sheesh
Ok, what is the correct way to shoot the base coat on urethane? i know urethane tends to flex and move and its kinda greasy a little. ive heard its a pain in the a** to paint. so i was wondering what is the best way to tackle the base coat? i dont want my paint to flake off.
Old Jul 27, 2001 | 02:33 PM
prjctCIVIC's Avatar
Default Re: Correct way to primer urethane? (HondaCRX)
use the SEM flexible flexible primer surfacer.....i used this on my kit and works very good..and is already premixed and ready to spray....
Old Jul 27, 2001 | 04:56 PM
nomorecrx's Avatar
New User
Default Re: Correct way to primer urethane? (prjctCIVIC)
yes, you will need some sort of flex agent.
Old Jul 28, 2001 | 03:03 PM
WuShu's Avatar
New User
Default Re: Correct way to primer urethane? (nomorecrx)
Actually i was probably gonna be using spray paint, but let me also ask you guys this, a friend of mines gave me this tip and i just wanted to see if it would work.
first sand with a rough grit
shoot base
wet sand with rough grit
shoot base
west sand with lighter grit
shoot base
then continue as many times as possible to get nice thick coat? will this work? can i primer with spray paints?
Old Jul 28, 2001 | 05:49 PM
prjctCIVIC's Avatar
priming with can primer is not gonna be thick enough.....but if you get ahold of a spray gun, i suggest you do it like this:
1 wetsand with 400 grit or scuff with red scotch brite pad
2 then shoot the primer
3 then wet sand again 400 or 600 grit then your ready to shoot color
gator88
Detailing
Feb 1, 2009 01:49 PM
stackz
Paint and Body
Apr 5, 2008 11:53 PM
LS_Integra_94
Jun 18, 2007 06:05 AM
sporadiccepheid
Jan 7, 2004 12:18 AM
stareatsun
Jan 2, 2004 12:20 PM
