car vibrates bad when turning right.
Old Jun 27, 2003 | 11:50 AM
Ivan's Avatar
senior gold member
Default car vibrates bad when turning right.
I was getting a really bad vibration almost like if the lugs nuts weren't tighten. I replaced the drivers side axle since it was bad. now I just get the same vibration(alot less though) when turning right. Could it be the other axle. Both axles were a few months old. its only when the clutch is engaged.
Old Jun 27, 2003 | 02:01 PM
Ivan's Avatar
senior gold member
Default Re: car vibrates bad when turning right. (Ivan)
237 views and no help does anyone have any other ideas besides the axle. I'm changing the axle right now.
Old Jun 27, 2003 | 02:02 PM
AtomicEG's Avatar
Yo man check your Bearings......
Old Jun 27, 2003 | 02:05 PM
crucial si's Avatar
is your hub tight enough?
Old Jun 27, 2003 | 02:19 PM
Ivan's Avatar
senior gold member
Default Re: (crucial si)
bearings and hubs are fine. I think its the axle but I wanna hear what else people think it might be.
Old Jun 30, 2003 | 01:25 PM
Ivan's Avatar
senior gold member
update: I switched the axle and its still doing. its weird cause its only doing it when I turn right. Can someone help me please
Old Jun 30, 2003 | 01:26 PM
Honda Kustums's Avatar
this might sound dumb but maybe tire rub?
Old Jun 30, 2003 | 01:29 PM
Ivan's Avatar
senior gold member
Default Re: (Honda Kustums)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda Kustums &raquo;</TD></TR><TR><TD CLASS="quote">this might sound dumb but maybe tire rub?</TD></TR></TABLE> I thought about that but it wasn't doing it before. it just started doing it after I had to brake really hard one day.
Old Jun 30, 2003 | 01:42 PM
thid92's Avatar
can I haz?
Default Re: car vibrates bad when turning right. (AtomicEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AtomicEG &raquo;</TD></TR><TR><TD CLASS="quote">Yo man check your Bearings......</TD></TR></TABLE>
Old Jun 30, 2003 | 01:46 PM
Ivan's Avatar
senior gold member
Default Re: car vibrates bad when turning right. (thid92)
wouldn't the bearings cause it to vibrate while going straight too? It only vibrates when I turn.
Old Jun 30, 2003 | 02:04 PM
quik1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ivan &raquo;</TD></TR><TR><TD CLASS="quote"> . its only when the clutch is engaged.</TD></TR></TABLE>
Sounds like it could be a tranny problem.
Old Jun 30, 2003 | 02:08 PM
Ivan's Avatar
senior gold member
Default Re: car vibrates bad when turning right. (quik1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quik1 &raquo;</TD></TR><TR><TD CLASS="quote">
Sounds like it could be a tranny problem.</TD></TR></TABLE>everyone I've talked says its not the tranny cause it doesn't do it when I'm going straight. Its gotta be somewhere in the driveline other then the tranny. also both axles have been replaced.
Old Jun 30, 2003 | 02:14 PM
Tomek's Avatar
bump for Ivan......help a brotha out guys because I dont know the answer either.
Old Jun 30, 2003 | 02:16 PM
stryderlis's Avatar
I have the same problem with my 2000 si. I'm still trying to figure it out.
Old Jun 30, 2003 | 02:36 PM
NonovUrbizniz's Avatar
Loved
here are my suggestions/questions...
are you on the brakes when you make these right turns? (could be you warped your rotors...)
Have you had your alignment checked?
Also if you are dropped really low you could have flat spotted PART of your tire that only hits the road when it's in a turn...
other than that probobly bent suspension piece... but that's not likely to happen from hard braking... unless you ended up hitting something.
Old Jun 30, 2003 | 06:03 PM
Ivan's Avatar
senior gold member
Default Re: car vibrates bad when turning right. (NonovUrbizniz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NonovUrbizniz &raquo;</TD></TR><TR><TD CLASS="quote">here are my suggestions/questions...
other than that probobly bent suspension piece... but that's not likely to happen from hard braking... unless you ended up hitting something.</TD></TR></TABLE>I'm not on my brakes when I make the turn. I haven't had my alignment checked yet but would it do it also when going straight? I've seen lower cars then mine. I didn't find any flat spots on my tires but I'll rotate them and see what happens. I haven't hit anything so I doubt anythings bent. Man I'm about to cry here, I can't figure it out.
Old Jun 30, 2003 | 09:17 PM
Ivan's Avatar
senior gold member
bump. I'm starting to hate this car.
Old Jun 30, 2003 | 09:22 PM
quik1's Avatar
Default Re: car vibrates bad when turning right. (AztecEJ)
It could still be the differential in the tranny.
Old Jun 30, 2003 | 09:24 PM
Ivan's Avatar
senior gold member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quik1 &raquo;</TD></TR><TR><TD CLASS="quote">It could still be the differential in the tranny.</TD></TR></TABLE>wouldn't it do it all the time though? not just when I turn right?
Old Jul 1, 2003 | 09:41 AM
Ivan's Avatar
senior gold member
should I take it to an alignment shop?
Old Jul 1, 2003 | 11:08 AM
Loved
I don't know the specifics of what happens when you have stock dif. problems but I know if it's locking fully or binding then it will ONLY make the noise around corners... but it would do it for left or right and you'd hear chirping out of your tires... (as it's forcing one to turn more times than it needs to on the inside of the corner).
Try jacking the front off the ground and cocking the wheel all the way right and spining just the wheel (with tranny in neutral)... if you can't hear the noise then try doing it with the engine running and it driving the wheels (be carefull wheels spinning freely in the air under power of the engine can rip up to redline FAST). If you don't hear it then it's probobly something in the suspension...
Wish I could be more help.
Old Jul 1, 2003 | 12:10 PM
minivan81's Avatar
check your intermediate shaft?
Old Jul 1, 2003 | 12:22 PM
B_CRUZ!'s Avatar
check your ball joints. my 87 beater had a mishaps yesterday which almost caused me to wreck it. the boot around the ball was bad and the ball popped out. I noticed something felt weird when I would turn LEFT. Something didn't feel right.
Now my 15" gs-r wheel is machined on the inner lip thanks to the lower front A-arm laying its weight on it.
Old Jul 1, 2003 | 01:29 PM
Ivan's Avatar
senior gold member
Default Re: car vibrates bad when turning right. (B.CRUZ)
okay I was checking things around and it seems my alignment is outta wack. I don't know what its called but my right tire is messed up. the front of the tire is facing outward a little bit kinda like this / now my question is this. If my cars alignment is messed up why does it vibrate only with the clutch engaged?
Old Jul 1, 2003 | 05:32 PM
Ivan's Avatar
senior gold member
okay here are some pics of my messed up alignment.
heres the left side
heres the right side Let me know if you guys think thats my problem. BTW this is with my steering pointing straight and you can see that the right side is the worst. The thing I still don't understand is why they're like this. I mean I didn't brake that hard. the brakes didn't even lock up.
