Difference between GSR rear lower sway bar and ITR sway bar?
I heard that the rear lower sway bars from the GSR and ITR are the same. Are they the same? I keep hearing they are but also that they are not.
JDMJAMES
http://www.JDMjunky.com
JDMJAMES
so would the GSR one be better than the stock RS one? I got a GSR one for free from my friend.
last i checked ls and gsr are different sizes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99civic_exSB »</TD></TR><TR><TD CLASS="quote">All Teg rear sway bars are the same size except for the ITR.</TD></TR></TABLE>
Here are the rear swaybar sizes:
LS 2dr: 13mm
LS 4dr:14mm
GSR 2dr/4dr: 14mm
LS 2dr: 13mm
LS 4dr:14mm
GSR 2dr/4dr: 14mm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THE94GSR »</TD></TR><TR><TD CLASS="quote">the type R i belive is 22mm and the jdm one is 23mm do a search on it theres alot of articles on this...</TD></TR></TABLE>
all usdm itr rear sways have been 22mm as were teh earlier jdm years but the latter changed to 23mm. So for those shoppin around for some rear itr sway bars... dont get swindled into payin more for a "jdm" itr bar if in fact its say a 96 spec and its only 22mm which would be the same as usdm.
If you wanna see some really good comparison pics go to my old thread of when i swapped out to the 22mm bar on my ls
https://honda-tech.com/zerothread?id=492383
and if u want full pics of install for the itr bar then go to my website linked in my sig then to the diy section.
for a 100 bucks this upgrade is worth every cent. your going to kick yourself and think you should have dont this earlier.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cramerox »</TD></TR><TR><TD CLASS="quote">for a 100 bucks this upgrade is worth every cent. your going to kick yourself and think you should have dont this earlier.
agreed. im doing the swap in a couple weeks.
</TD></TR></TABLE>agreed. im doing the swap in a couple weeks.
navin
Oct 29, 2002 05:04 PM
mamaboy
Oct 29, 2001 10:30 AM
full size here
