Hard to shift into 2nd at around 50-70km/h?
Old Jul 26, 2001 | 05:17 AM
Ideal R's Avatar
New User
Default Hard to shift into 2nd at around 50-70km/h?
anyone experience this?
when i am going at around 50-70km/h and come to a turn, i try to down shift to 2nd
i push the clutch all the way down, move the stick to 2nd, and find there is quite a bit of resistance. i can still put it in 2nd, but need a bit more force
and my 2nd has more resistance than other gears (except 1st) in general too
is this normal?
thx!
Old Jul 26, 2001 | 05:35 AM
jonnyR's Avatar
Default Re: Hard to shift into 2nd at around 50-70km/h? (ITR #01-1203)
I have the same problem.....I have started double clutching when down shifting too and it seems to be better. However, I'd like to know why too.
Old Jul 26, 2001 | 06:44 AM
MiraiZ's Avatar
its because of the close gears....the syncros dont line up well.....double clutching is a good solution
Old Jul 26, 2001 | 06:46 AM
TRuST's Avatar
Try getting the RPM higher to allow you to shift into 2nd.
Old Jul 26, 2001 | 06:48 AM
Boba-Fett's Avatar
New User
Default Re: Hard to shift into 2nd at around 50-70km/h? (jonnyR)
you know what happens when you double clutch on a road course?
I pass your ***!!!!!
Old Jul 26, 2001 | 08:38 AM
Ideal R's Avatar
New User
Default Re: Hard to shift into 2nd at around 50-70km/h? (MiraiZ)
thx guys, makes me feel better
btw, if i don't double clutch or make higher rpm before downshift into 2nd, will i damage the syncros?
Old Jul 26, 2001 | 08:45 AM
Ross's Avatar
25 Year Member
Community Builder
Community Influencer
Active Streak: 30 Days
if you just yam it into 2nd, it's not good for tranny or engine. I can get it to the point where without double-clutching, I can blip the throttle perfectly and get it intolower gear without unsettling the car. Double-clutching is nice, but we are not driving Espadas or MGs and it's not necessary...as Boba alluded to, it's slower as well. On a road course, the only way to really get the most out of your downshift is heel-and-toeing.
Old Jul 26, 2001 | 08:46 AM
Type R 1090's Avatar
New User
Yup same thing here. I find anything 40km/h or lower and it goes into 2nd pretty easily. If it doesn't go in easily, just wait till you drop to a lower speed or double clutch. Don't just force it it.
[Modified by Type R 1090, 9:52 AM 7/26/2001]
Ef4doorwagon
Nov 28, 2014 10:17 PM
JDMlyfestyle
21
Sep 24, 2004 02:08 PM
VtecDA9
Jul 16, 2003 05:47 AM
94GSRNewbie
Aug 4, 2001 11:48 PM
