Air conditioning help
Old Jun 27, 2003 | 09:33 AM
clm's Avatar
clm
Default Air conditioning help
Well, the air conditioning on my D16Y8 still won't work even with a fresh charge of 134. It's holding the "coolant," the fan kicks on, and the idle jumps up. Any thoughts as to what might be the problem? I'd like to get it running cheaply for the summer, but if I don't get it running within the next couple days I'm ripping it out. No sense in carrying dead weight.
Thanks for any insight.
Old Jun 27, 2003 | 02:13 PM
Sipower99's Avatar
Default Re: Air conditioning help (clm)
the compressor gone bad maybe?
Old Jun 27, 2003 | 07:46 PM
clm's Avatar
clm
Default Re: Air conditioning help (Sipower99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sipower99 &raquo;</TD></TR><TR><TD CLASS="quote">the compressor gone bad maybe?</TD></TR></TABLE>
Perhaps, but I'm unsure of how to test it.
Any other thoughts?
Old Jun 27, 2003 | 08:07 PM
94HybridEX's Avatar
Do you see/hear the compressor turn on? Same goes for the fan - is it turning on? Check the wiring. If all of those work, make sure your blower is working. Also, turn your a/c on recirculate and blast that on a warm day. See if you the low pressure line sweating. If you do, you know the lines are getting cold and theres a problem most likely near the inside of the car.
Old Jun 27, 2003 | 08:09 PM
97civicdx's Avatar
Default Re: Air conditioning help (94HybridEX)
If you dont see the a/c comp cycling, meaning you see the clutch engage and disengage, then its the compressor.
Old Jun 27, 2003 | 08:14 PM
clm's Avatar
clm
Default Re: Air conditioning help (97civicdx)
Thanks for the responses; I'll be sure to test it out tomorrow.
Old Jun 27, 2003 | 08:59 PM
Rhythm Racer's Avatar
I have the same problem,,,i recharged the freon and it worked gret very cold but then a week later its back to hot air , i think i just have a leak!!!!
Old Jun 28, 2003 | 07:08 AM
clm's Avatar
clm
Default Re: Air conditioning help (Rhythm Racer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rhythm Racer &raquo;</TD></TR><TR><TD CLASS="quote">I have the same problem,,,i recharged the freon and it worked gret very cold but then a week later its back to hot air , i think i just have a leak!!!! </TD></TR></TABLE>
You can get a leak seeler and tester at an autpoarts store for less than $5. It emits a red dye with leaks it can't seel.
Old Jun 28, 2003 | 07:27 AM
97civicdx's Avatar
Mine blows at 40 degree's.................
Old Jun 28, 2003 | 08:44 AM
clm's Avatar
clm
Well, it seems it isn't holding a charge. And the parts to fix the leaks will most likely be expensive, so I'm just going to rip it out. It's no longer worth the time or money - especially when I'll probably take it out this fall anyway.
Thanks for the help.
mrspeedy69
Jun 28, 2011 09:56 AM
LsVtecFoti
Apr 20, 2008 11:23 PM
dont_tri
Jul 30, 2007 08:02 AM
devilpuppy
Jun 11, 2005 08:34 AM
NoNOSgsr!
Aug 27, 2003 03:34 AM
