compression ratio: how high is too high??
Old Jun 27, 2003 | 09:28 AM
Mar_DC2's Avatar
Default compression ratio: how high is too high??
i was just thinking about this the other day. ive seen people on here who say their CR's are 12.0:1 and above on their street car. to me that seems too high for a daily driver. i think anywhere between 11.0-12.0 would be good enough for me. how do you guys with 12.0 and higher get around, what kind of fuel do you use, etc.??
Old Jun 27, 2003 | 10:17 AM
Spade's Avatar
Default Re: compression ratio: how high is too high?? (Btown_99Si)
93 octane and good tuning.
Old Jun 27, 2003 | 10:21 AM
Evs-One's Avatar
Solbros Owns Me
Default Re: compression ratio: how high is too high?? (Spade)
my friend runs 12.5:1 on 92 octane, tuned on Hondata, 30 mpg highway, 220 whp, 12.6 1/4 mile in an all metal GSR
edit- he tried 13:1 with 92 octane, and ended up pulling so much timing, the power to the ground was the same as 12.5:1
Old Jun 27, 2003 | 10:24 AM
allmtr's Avatar
Default Re: compression ratio: how high is too high?? (Emerika)
i got 12.0:1 CR and im on 91 octane. my timing is at 12 and its tuned with vafc. make sure u have all
the proper fuel accesories like pump, fpr... rail and injectors arent as important
Evs-One's Avatar
Solbros Owns Me
Default Re: compression ratio: how high is too high?? (allmtr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmtr &raquo;</TD></TR><TR><TD CLASS="quote">i got 12.0:1 CR and im on 91 octane. my timing is at 12 and its tuned with vafc. make sure u have all
the proper fuel accesories like pump, fpr... rail and injectors arent as important</TD></TR></TABLE>
with Hondata your timing could be at 16...gain a lot of power
Old Jun 27, 2003 | 10:29 AM
allmtr's Avatar
really??? hmmmm. i was ganna get a thicker head gasket and run more timing, but a hondata sounds better
Old Jun 27, 2003 | 10:53 AM
Evs-One's Avatar
Solbros Owns Me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmtr &raquo;</TD></TR><TR><TD CLASS="quote">really??? hmmmm. i was ganna get a thicker head gasket and run more timing, but a hondata sounds better</TD></TR></TABLE>
sell your VAFC for 225 or so, and you're more than 1/2 way to s200 with launch control, full throttle shifts and data logging. Find smeone that can tune good, and you'll see FAR better results than a VAFC
Old Jun 27, 2003 | 10:56 AM
Pacman
Guest
Posts: n/a
WHAT IS YOUR GOAL IN hp THAT THE MOST IMPORTANT THING THAT LIKE TO KNOW?
Old Jun 27, 2003 | 10:57 AM
Evs-One's Avatar
Solbros Owns Me
Default Re: compression ratio: how high is too high?? (Pacman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pacman &raquo;</TD></TR><TR><TD CLASS="quote">WHAT IS YOUR GOAL IN hp THAT THE MOST IMPORTANT THING THAT LIKE TO KNOW?</TD></TR></TABLE>
WHY ARE YOU TALKING ALL IN CAPS, THAT IS THE MOST IMPORTANT QUESTION HERE AT HAND...
Old Jun 27, 2003 | 10:59 AM
allmtr's Avatar
well i got a built ls/vtec with a fully done up p&p and milled head with itr cams, gsr crank and ctr pistons. all the bolt ons and i dynoed at 204 whp and 141 tq. not bad but id like to see better with bigger cams
im really thinking of selling it and working towards an i-vtec swap. maybe just a k24 for now to get started.
Old Jun 27, 2003 | 05:20 PM
Draco's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Emerika &raquo;</TD></TR><TR><TD CLASS="quote">my friend runs 12.5:1 on 92 octane, tuned on Hondata, 30 mpg highway, 220 whp, 12.6 1/4 mile in an all metal GSR
all metal?
Old Jun 27, 2003 | 05:45 PM
BanUglyImportModel's Avatar
im a noob with compression? I plan on puttin on ctr pistons and jun 3 cams. I think ctr are 12:1 compression on a gsr motor but what does that mean? I think the higher the more power i assume. But what does the 12 represent and what does the 1? Please enlighten me. Thanks
Old Jun 27, 2003 | 05:55 PM
HXMan's Avatar
Default Re: (BanUglyImportModel)
Basicly with more compression you make more power.
I have heard 1 cr up equals about 10hp...not sure on that though.
Old Jun 27, 2003 | 06:04 PM
allmtr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BanUglyImportModel &raquo;</TD></TR><TR><TD CLASS="quote">im a noob with compression? I plan on puttin on ctr pistons and jun 3 cams. I think ctr are 12:1 compression on a gsr motor but what does that mean? I think the higher the more power i assume. But what does the 12 represent and what does the 1? Please enlighten me. Thanks</TD></TR></TABLE>
12:1 for example: like squeezing 12 oranges down to the size of 1.
10.4:1 for example: squeezing 10.4 oranges to the size of 1.
it will always end in :1
the more you squeeze the air in the cylinder to, the bigger explotion u get. more power
Old Jun 27, 2003 | 06:35 PM
Default Re: (allmtr)
the more you squeeze the air in the cylinder to, the bigger explotion u get. more power</TD></TR></TABLE>
So basically higher compression pistions allow more air in the chambers and make it push up and down harder making more power. think i get it. Thanks alot
Old Jun 27, 2003 | 10:08 PM
Mar_DC2's Avatar
wow, i didnt think a VAFC could be tuned that well for 12:1. maybe im just over-estimating everything.
with compression ratio's, the 1 represents the volume in the combustion chamber at TDC, and the 12, or 10.2, or whatever number comes before the 1 represents the volume at BDC. so with a 12:1 compression ratio, the volume is 12x larger at BDC than the volume at TDC. thats why its called "compression" ratio because the 12 is compressed into 1. so to my understanding its not necissarilly more air in the combustion chamber, its more air per cubic inch. basically its just more volume is compressed into less volume. im probably wrong, but thats how it was explained to me.
Old Jun 27, 2003 | 10:37 PM
SpoonFedHatch's Avatar
Default Re: (Btown_99Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Btown_99Si &raquo;</TD></TR><TR><TD CLASS="quote">wow, i didnt think a VAFC could be tuned that well for 12:1. maybe im just over-estimating everything.
with compression ratio's, the 1 represents the volume in the combustion chamber at TDC, and the 12, or 10.2, or whatever number comes before the 1 represents the volume at BDC. so with a 12:1 compression ratio, the volume is 12x larger at BDC than the volume at TDC. thats why its called "compression" ratio because the 12 is compressed into 1. so to my understanding its not necissarilly more air in the combustion chamber, its more air per cubic inch. basically its just more volume is compressed into less volume. im probably wrong, but thats how it was explained to me. </TD></TR></TABLE>
i never knew there was such thing as BDC??
Old Jun 27, 2003 | 10:43 PM
DCStreetHtch's Avatar
Default Re: (SpoonFedHatch)
BDC????
good thread lets keep it alive!
-Bryan-
Old Jun 27, 2003 | 11:10 PM
Mar_DC2's Avatar
Default Re: (EGStreetHtch)
haha, its 1 am, im too tired to care about engine terminology right now.
so whatever the term is when the piston is at the lowest point of the stroke is what BDC means??
oMek
12
Jun 9, 2004 11:54 AM
Revhard92si
Jun 4, 2004 10:48 AM
TrueZen
May 30, 2003 06:14 AM
M SPEC
Jan 14, 2003 12:08 PM
itr501
Mar 3, 2002 05:09 PM
