NGK Coppers spark plugs....BKR6E-11 ??
Guest
Posts: n/a
I just ran out to get some new plugs for the old GS-R, and naturally I went with what the Honda Gods recommended (NGK coppers). the problem is that when I got the spark plug package, it didn't say anything about copper at all. All it said on the front was "V-Power". I double checked the stock #, and it said BKRE-11...that is the stock # for NGK coppers right ? Did I get the right plugs ?
look under your hood and read the sticker. It will list your options in NGK plugs. Model codes are listed for your convenience.
read your labels
read your labels
Those plugs are gapped WAY to close when you first get them. The 11 in the stock number refers to a gap of 1.1mm, but usually go more like 1.3mm which is what the factory recommends.
Rob.
May 6, 2009 01:31 PM
EL'ation
Aug 5, 2002 01:12 PM
