Prelude cluster in accord?
Old Jun 27, 2003 | 09:15 AM
dc4drewH's Avatar
Default Prelude cluster in accord?
Not sure if I am posting this in the right forum either prelude or accord. But one of my buddies has a 2Dr 96 accord EX and wants to know if a 97 and up prelude cluster would work without any custom fabrication? Any advice is helpful thanks
Old Jun 28, 2003 | 08:44 AM
Sinisterh22a's Avatar
Default Re: Prelude cluster in accord? (dc4drewH)
there is a guy who did that in his 5th gen accord and he said it was a pain in the *** not sure who he is he is on cardomain.com look up accords it is white he had to rewire everything from the ecu to the cluster i believe
Old Jun 30, 2003 | 05:50 AM
tiaccordsh's Avatar
hey man,, it was me. Hes right, it was a pain in the ***
http://www.cardomain.com/membe...ccord
Old Jun 30, 2003 | 05:53 AM
iakona's Avatar
how'd you do that?
Old Jun 30, 2003 | 06:17 AM
KGAccord's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc4drewH &raquo;</TD></TR><TR><TD CLASS="quote">Not sure if I am posting this in the right forum either prelude or accord. But one of my buddies has a 2Dr 96 accord EX and wants to know if a 97 and up prelude cluster would work without any custom fabrication? Any advice is helpful thanks</TD></TR></TABLE>
i hope your buddy has a H22 under his hood..otherwise
Old Jun 30, 2003 | 07:52 AM
92hybridAccord's Avatar
From: In the heart of the ghetto of the, Suburbs NYC
what wire did you hook up for your speedometer to work...i got the red black hooked up...but no luck..any help would be appreciated...thanks
Old Jun 30, 2003 | 09:22 AM
DeLiRiOu5's Avatar
Default Re: (92hybridAccord)
haha this pic is more than enough to keep me from wanting to do this if i ever get an h22
Old Jun 30, 2003 | 09:46 AM
haha...DeLiRi0u5
Don't be too intimidated, it isn't that hard....i think he totally rebuild and changed the harness in that image...
Only the cluster and the wiring needs altering behind the cluster...i will post up pics of mine when i can...
I got all gauges except for the speedo, and the oil light...that shyt stays on..lol
but clust looks great otherwise
Old Jun 30, 2003 | 01:50 PM
whoa its len 2's Avatar
how much would a shop charge to do a 97+ lude cluster in a 5th gen? that pic does look intimidating for me to diy.
Old Jun 30, 2003 | 04:25 PM
tiaccordsh's Avatar
Default Re: (whoaitslen2)
its really not as bad as that pic shows.. I dont have any idea how much a shop would charge,
Old Jun 30, 2003 | 04:34 PM
tiaccordsh's Avatar
Default Re: (DeLiRiOu5)
mine is a type sh cluster (not sure if its any diffferent) but if I recall correctly, there was a blue/white wire for the VSS and a black ground wire. Im not sure how you are doin it, but I used the guage section of the lude harness and spliced into the accord harness wire for wire. I used the wiring books for each and began matching colors.
Old Jun 30, 2003 | 08:22 PM
Zuerst's Avatar
A bit off topic but how exactly do you take off the entire dash piece? Is diabling the airbags necessary?
Old Jun 30, 2003 | 08:36 PM
FG Two's Avatar
you could just get a jdm accord sir cluster from japan like me!
Old Jun 30, 2003 | 08:39 PM
Default Re: (tiaccordsh)
so it was pretty much matching the accord wires to the prelude harness? sounds straight forward. was there any extra wires from either side? and how is the actual fitment of the cluster.. did it bolt right up or was there any mounts and brackets fabricated? thanks..
Old Jul 1, 2003 | 03:50 AM
tiaccordsh's Avatar
everything I wanted hooked up, I used the wires for. I chose not to hook up my seatbelt indicator. Anyway, its not a bolt up as much as it is a wedge w/ some filler black rubber. If you look lcosely you can see some very small gaps on the side that I put the rubber behind. other than that, it fits very well, and doesnt shake or vibrate any more than anything else on our 5th gens
Old Jul 1, 2003 | 04:45 AM
he's rite...the cluster doesn't exactly sits in the accord cluster space, but you can shift around to get that perfect look...so it blends and you can't tell the diff unless you look closely...
About the wiring..it's mainly matching...i didn't do the harness splice, because i got my lude cluster with the harness connector removed, so it was alot of electrical taping, which i need to clean up....I tried my best to connect all that i could, and i think i have the rite vss connected, but i will check again this weekend, but i also know that the speedo could have went bad...so that kills that idea...
great project especially for swapped accords
Old Jul 1, 2003 | 05:24 AM
DC5_R's Avatar
Default Re: Prelude cluster in accord? (Phat4drVtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phat4drVtec &raquo;</TD></TR><TR><TD CLASS="quote">you could just get a jdm accord sir cluster from japan like me! </TD></TR></TABLE>
How much, how and where?
Old Jul 1, 2003 | 09:14 AM
miege44's Avatar
is this doable in 4th gens?
Old Jul 1, 2003 | 09:55 AM
tiaccordsh's Avatar
Default Re: (miege44)
anything is doable w/ the right amt of time/money etc. is the shape of the cluster even close to that of a 4th gen?
Old Jul 1, 2003 | 10:05 AM
unfortunatel it won't be a easy job for the 4th gen cluseter accords..the 97+ ludes have a total different shape and size...sorry man
Old Jul 1, 2003 | 10:08 AM
iakona's Avatar
Default Re: Prelude cluster in accord? (Inspire95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Inspire95 &raquo;</TD></TR><TR><TD CLASS="quote">
How much, how and where? </TD></TR></TABLE>
ebay. anywhere from $80 to $200. i got one too. very cool. just have to keep track of my maintenance in Km instead of miles.
Old Jul 2, 2003 | 10:39 AM
dc4drewH's Avatar
Thanks for the feedback. Are you going to post those pics, because now my buddy wants a lude cluster.
92hybridAccord
Aug 1, 2017 11:42 PM
subgeniusdude
Jul 25, 2005 08:40 PM
mayfieldfour
May 19, 2004 12:59 PM
BigChris
Sep 3, 2003 10:48 AM
H22TurboATR
Nov 14, 2001 03:44 PM
